Kinetic Energy of a sphere due to uniform line of charge
The discussion focuses on calculating the kinetic energy of a small sphere with a positive charge of 6.00 µC, released from rest at a distance of 1.20 cm from a long line of uniform linear charge density of 4.00 µC/m. The correct approach involves using the potential difference derived from the electric field of the line charge, applying Gauss's Law, and integrating to find the work done. The final kinetic energy calculated is -0.598 J, confirming the correct application of the formulas for potential energy and kinetic energy conversion.
  • Understanding of electric potential due to a line of charge
  • Familiarity with Gauss's Law
  • Knowledge of kinetic and potential energy conversion
  • Basic calculus for integration in electric field calculations
  • Study the derivation of electric potential from an infinite line of charge
  • Learn about Gauss's Law and its applications in electrostatics
  • Explore the relationship between work, potential energy, and kinetic energy
  • Practice problems involving electric fields and potentials in various charge configurations
Students in physics, particularly those studying electromagnetism, as well as educators and anyone seeking to understand the principles of electric fields and energy conversion in charged systems.
zabumafu
A very small sphere with positive charge 6.00uC is released from rest at a point 1.20cm from a very long line of uniform linear charge density 4.00uC/m.What is the kinetic energy of the sphere when it is 4.80cm from the line of charge if the only force on it is the force exerted by the line of charge?
Well we have not gone over this in class so I have no notes and can't seem to find a solution online. All I could think about doing was solving for the change in potential from the initial point at 1.2cm and since its at rest, all of the energy lost will be converted in kinetic.
So change in potential=-W/q with q being the charge of the particle.
Vi=initial potential
Vf=final potential
Vi=k(lamda)ln(xi)
=(8.99*10^9)(4.0*10^-6)ln(.012)
=-1.59*10^5
Vf=(8.99*10^-9)(4.0*10^-6)ln(.048)
=-1.09*10^5
dV=-4.985*10^4=-W/q
W=49.85*(6.0*10^-6)
W=K=.299J?
The answer is wrong but I have no other formulas to determine potential of a uniform line of charge.
Does the symbol uC stand for microCoulomb or nanoCoulomb?
microCoulomb sorry should have noticed that before and just noticed I did nano, so let me rework that however I only have 1 more attempt at the problem so I want to make sure its right. I corrected it to .299J I believe using microCoulombs
Are you sure you got the numerical factor in front of the natural log function correct? Maybe a factor of 2 or 1/2 or something?
I am not sure, I used the only equation involving lambda provided by our book. If your hinting that there is, I'd say by a factor of 1/2 but can't explain why other than by basing it off of other derived equations.
You should be able to consult the source from which you got your formula. Or do a web search for the potential of an infinite line of charge.
My book (the source I was using) says the potential due to a continuous line of charge is
V=(λ/4∏εo)ln[(L+(L^2+ d^2)^.5)/d] however what confused me is if L is infinitely long and ignored, that turns the natural log portion of the function into +-d/d
As is the case for finite charge distributions, that potential goes to zero as d → ∞ .
However, if you let L → ∞ , then the potential is not defined for any finite value of d .
Use Gauss's Law to find the electric field a distance r, from an infinitely long line of charge with linear charge density, λ . Then use:
\displaystyle V(b)-V(a)=-\int_{a}^{b}\,\vec{E}\cdot d\vec{r}​
Perfect so
dV=-λ/2πεo[ln(a)/(b)]
=[-(4.0*10^-6)/2π(8.85*10^-12)]*ln(.048/.012)
dV=-99725V
dV=U/q
U=K=-.598J which was correct
  • · Replies 23 ·
