Klein-Gordon: Schwarzschild Metric, Physically Acceptable?
The discussion confirms that solutions derived from the Klein-Gordon equation using the Schwarzschild metric are physically acceptable. The Klein-Gordon equation describes wave propagation for massive fields without non-gravitational interactions. It is established that if the assumptions of General Relativity (GR) and the existence of a massive field are met, then physically realizable solutions can be obtained. Furthermore, failure to satisfy the Klein-Gordon equation indicates a violation of local momentum-energy conservation, which can occur if momentum-energy interacts with other fields.
  • Understanding of the Klein-Gordon equation
  • Familiarity with the Schwarzschild metric in General Relativity
  • Knowledge of wave propagation in physics
  • Concept of local momentum-energy conservation
  • Explore the implications of the Klein-Gordon equation in curved spacetime
  • Study the relationship between the Schwarzschild metric and wave-like phenomena
  • Investigate the conservation laws in General Relativity
  • Learn about interactions between fields in quantum field theory
Physicists, researchers in theoretical physics, and students studying General Relativity and quantum field theory will benefit from this discussion.
Vitani1
Does this give solutions which are physically acceptable?
Yes.
Moderator's note: Moved thread to relativity forum.
A bit of context could help.
If you use the Schwarzschild metric in the Klein-Gordon equation (see attached) and derive the equation for the particle as a function of its position in time and space, do you get physically realizable solutions? This is my question.
Understand that the Klein-Gordon equation encodes the propagation of waves for massive fields in the absence of non-gravitational interactions with the field. If you can physically realize those assumptions (and GR) and you can physically realize a massive (including special case m=0) field. Thus: "Yes."
Failure to satisfy K-G is failure to conserve local momentum-energy. That's not impossible, the system can be "bleeding" momentum-energy into or out of some other field via interaction but one must assume it may also not do so.
When you say absence of non-gravitational interactions within the field you mean to say that solving this for the Schwarzschild is effective in explaining wave-like phenomena in the presence of gravity exclusively?
I meant to include in the previous post the presence of gravity or the absence of a field.
  • · Replies 28 ·
  • · Replies 50 ·
