Lab question regarding cylinders
  • Thread starter Thread starter protossadv
    Cylinders Lab
5 replies · 2K views
protossadv
hi
im trying to do a lab on rotational inertia of a hollow cylinder
i plan to roll a hollow cylinder down an incline
and see how the inner radius, outer radius, and mass affects the final translational velocity
but i am not sure what i can use for the cylinder
to sufficiently control and alter the variables
does anyone have any ideas?
thanks in advance
Different sizes of pipe -- iron pipe, plastic pipe, and so on.
Empty "tin" cans of various sizes with the ends cut off.
Surely you can think of more...
Try two identical cans of mushroom soup, one at room temperature and one left in the freezer overnight.
An easy way to control other variables such as density might be to use a cylinder in which you can drill holes of different sizes.A broomstick and a candle come to mind.You can get candles of very large radii.
Only if it's Campbells mushroom soup:biggrin:
pipes are a bad idea because i would need at least 15 data different data values and i can't really slowly increase or reduce the radius
i also need uniform density so i can't use different types of pipes
freezing a can would also just give 2 data values which would not be enough
i think that's a great idea and its worth a try
but does anyone kno anything kind of like tissue or tape
that i can constantly wrap around to increase the radius?
it would be great if its much thicker than tissue because tissue would take forever to increase the radius
thanks in advance
