Lamor precession and diamagnetism
The discussion centers on Larmor precession and its relationship with diamagnetism. Larmor precession occurs when a magnetic moment, such as that of an electron with spin, is subjected to a homogeneous magnetic field, resulting in a torque that induces movement with constant angular velocity. Diamagnetism, characterized by the generation of a magnetic field opposing an external magnetic field, complicates the understanding of Larmor precession, particularly regarding the internal magnetic field generated during this process. The conversation highlights the need for clarity on the equations governing these phenomena and their implications in materials exhibiting diamagnetic properties.
  • Understanding of Larmor precession and its principles
  • Familiarity with diamagnetism and its characteristics
  • Knowledge of vector equations and their applications in physics
  • Basic concepts of magnetic moments and angular momentum
  • Study the equations governing Larmor precession and their derivations
  • Research the principles of diamagnetism and its effects on different materials
  • Explore the applications of Larmor precession in magnetic resonance imaging (MRI)
  • Investigate the conditions under which diamagnetic materials can be resonated
Students and researchers in physics, particularly those focusing on magnetism, materials science, and magnetic resonance technologies.
Gavroy
i have some troubles to understand the lamor precession properly and i need your help to correct my errors:
so in order to get the lamor precession: afaik you need something that causes a magnetic moment, e.g. an electron with spin or angular momentum.
then you need a homogenous magnetic field and it is necessary, that the direction of the field and the direction of the magnetic moment are not exactly the same if you want to measure at least something.
now, there is a torque, that leads to this movement with constant angular velocity
is this right so far?
but: at this point i heard, that it has something to do with diamagnetism and this is what actually confuses me.
diamagnetism means, that the body creates a magnetic field that is opposed to the external magnetic field.
but if this torque that is caused by the lamor precession leads to an additional magnetic field, how do you know, that it is always opposed to the external one?
and which equation gives me the internal magnetic field, that is caused by the lamor precession?
sorry for my english, i am still practising.
English: is good, I understand your questions just fine.
You mean Larmor precession.
Try reading here: do you understand vector equations?
http://en.wikipedia.org/wiki/Larmor_precession
Also note the APPLICATIONS links near the end of the article.
diamagnetism...how do you know, that it is always opposed to the external one?
just as you know friction always opposes an applied force...so electrons will try to return to their original orientation which is in opposition to the applied external magnetic field.
http://en.wikipedia.org/wiki/Diamagnetism
Diamagnetism is a very general phenomenon, because all electrons, including the electrons of an atom, will always make a weak contribution to the material's response. However, for materials that show some other form of magnetism (such as ferromagnetism or paramagnetism), the diamagnetism is completely overpowered. Substances that mostly display diamagnetic behaviour are termed diamagnetic materials, or diamagnets
Diamagnetic resonance
Can the electrons/protons of a diamagnetic material be resonated? I understand that you cannot detect a signal from diamagnetic materials because the signals from each electron cancel each other out. However, can the electrons/protons be excited at certain frequencies just like hydrogen (one proton) in MRI?
