Laplace Transformation and unit step func
The discussion centers on expressing the function f(t) = e^t for 0 < t < 2 using the unit step function in the context of Laplace transformations. The correct formulation involves the shift theorem, specifically L(f(t)u(t-a)) = e^{-as}L(f(t+a)), which allows for the proper representation of f(t) in terms of unit step functions. The final result is derived as L(F(s)) = (1 + e^{-2s}) / (s(s-1)), confirming the validity of the approach through integration and the use of unit step functions.
  • Understanding of Laplace transformations and their properties
  • Familiarity with unit step functions, denoted as u(t)
  • Knowledge of the shift theorem in Laplace transforms
  • Basic calculus for evaluating integrals
  • Study the shift theorem in Laplace transforms in detail
  • Learn how to apply unit step functions in piecewise defined functions
  • Practice solving Laplace transforms of functions defined over specific intervals
  • Explore graphical interpretations of unit step functions and their effects on f(t)
Students and professionals in engineering, mathematics, and physics who are working with Laplace transformations, particularly those focusing on piecewise functions and their applications in control systems and differential equations.
Susanne217
I am given the following
f(t)= e^t where 0<t<2
express the function f(t) in the terms of the unitstep func.
I am told that the f(t) can be expressed
\mathcal{L}(f(t-a)u(t-a)) = e^{-as}F(s)
where F(S) = \mathcal{L}(f(t))
then
\mathcal{L}(f(t-0)u(t-0)) = \frac{1}{s}
and
\mathcal{L}(f(t-2)u(t-2)) = e^{-2s} \frac{1}{s-1}
I am told that I need to add the two together (what is my motivation for doing this?)
and if I do this I get
\mathcal{L}(F(s)) =\frac{1+e^{-2s}}{s(s-1)}
what am I doing wrong here?
Best Regards
Susanne
edit: I have discovered that if I take the place integral
\mathcal{L}(f(t)) = \int _{0}^{2} e^{-st} \cdot e^{t} dt = \frac{e^{t-st}}{1-s}|_{t=0}^{2} = \frac{1-e^{2-2s}}{1-s}
which is desired result according to the textbook. But how do I show that this can the found using the original method above?
When you write your f(t) in terms of unit step functions you should get:
f(t) = et(u(t-2) - u(t))
= etu(t-2) - etu(t)
[Edit] signs wrong here, should be:
etu(t)-etu(t-2)
The first term is not in the form f(t-a)u(t-a). It is of the form f(t)u(t-a).
Have you had this form of the shift theorem:
L(f(t)u(t-a)) = e-asL(f(t+a)) ?
It is what you generally want for this type of transform. Try it and you will get your correct answer.
= etu(t-2) - etu(t)
Hi maybe this is stupid question the reason why you subtract is it because because it can be seen as an integral? And that being the reason why what I get with the integral is the same result?
"Hi maybe this is stupid question the reason why you subtract is it because because it can be seen as an integral? And that being the reason why what I get with the integral is the same result?"
No. etu(t-2) is zero up until t = 2, then it is et.
etu(t) agrees with et for t > 0.
Look at the graphs of those. You need to subtract the part for t > 2 to get 0 for t > 2. That is why you subtract the u(t-2) part.
For that reason, if b > a, u(t-a) - u(t-b) is sometimes called a filter function. Because if you multiply any f(t) by that what you get is just the portion of f(t) on [a,b] and zero elsewhere.
They are very useful in LaPlace transforms for taking transforms of piecewise defined functions.
You got the correct result when you integrated because you computed the transform directly and correctly. But you should still learn to do it with the shift theorem. Did you try what I suggested?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
