Laplace Transforms to solve First Order ODE's.
The discussion focuses on solving a system of first-order ordinary differential equations (ODEs) using Laplace Transforms. The equations are dx/dt = x - 4y and dy/dt = x + y, with initial conditions x(0)=3 and y(0)=-4. Participants clarify the application of the Laplace Transform, particularly the linearity property, and guide the user through isolating L[y] and applying inverse transforms. The final expressions derived include L[y] = (3 - 4(s - 1)) / ((s - 1)^2 + 4) and the use of the frequency shift rule for obtaining y(t).
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with Laplace Transforms and their properties
  • Knowledge of inverse Laplace Transforms
  • Basic algebraic manipulation skills
  • Learn the properties of Laplace Transforms, including linearity and the frequency shift rule
  • Study inverse Laplace Transform techniques for solving ODEs
  • Explore examples of solving systems of differential equations using Laplace Transforms
  • Review common Laplace Transform pairs and their applications
Students studying differential equations, mathematicians, and engineers seeking to apply Laplace Transforms for solving first-order ODE systems.
WrittenStars
Solve the system of first order differential equations using Laplace Transforms:
dx/dt = x - 4y
dy/dt = x + y,
subject to the initial conditions x(0)=3 and y(0)=-4.
So far I've used the limited knowledge of Laplace Transforms for first order ODE's to get this far:
L[x`] = L[x] - L[4y]
s*L[x] - x(0) = L[x] - L[4y]
s*L[x] - L[x] - 3 = -L[4y]
(s-1)*L[x] = 3 + L[4y] <--------- Equation 1
L[y'] = L[x] + L[y]
s*L[y] - y(0) = L[x] + L[y]
s*L[y] + 4 = L[x] + L[y]
(s-1)*L[y] = L[x] - 4 <----------Equation 2
or (s-1)*L[y] + 4 = L[x]
Up to this stage I am kind of confident I have been using Laplace Transforms right (from the couple of examples I have in a textbook I got from the library).
The step where I become very confused is substituting equations 1 and 2 into one another to evaluate y(t) and x(t).
When I substitute (2) into (1) i get the following:
(s-1)[(s-1)*L[y] + 4] = 3 + L[4y]
From here I have probably tried 20 different ways of getting a solution for y(s) but every single one is very complicated and leads to a dead end for me (they are way too long to type). Because of this I suspect I am doing something wrong here [potentially I am even applying Laplace Transforms completely wrong!].
I am hoping someone knows where I am going wrong or what I'm doing wrong. Any help and advice would be greatly appreciated, thanks!
Looks good so far. Remember that the Laplace transform is linear, so you can say L[4y]=4 L[y]. Then it's just basic algebra to isolate L[y]. You should get
L[y] = \frac{3-4(s-1)}{(s-1)^2-4}
Keep in mind that L[4y]=4L[y]:wink:
EDIT: Vela beat me to it.:smile:
Thanks a lot for the replies guys, really appreciate it. Hmm I just made a small mistake in isolating L[y], I got that bit now thanks to your help!
I have worked at it and did get:
[3-4(s-1)] / [(s-1)^2 - 4]
It's what I do from here to get y(t) that's confusing me now. I can't seem to find a way to isolate y and get a general solution for it. Sorry I'm not great with maths yet, just starting and keen.
Just take the inverse Laplace transform of both sides of your equation now.
L^{-1}[L[y]]=y(t)=L^{-1}\left[\frac{3-4(s-1)}{(s-1)^2-4}\right]
I've simplified the numerator to get:
(7-4s) / [(s-1)^2 - 4]
From here I suspect I should break the expression up into 2 parts and compare them to the table of Laplace transformations (from other questions I've done). But I just can't find the right parts and Laplace transformations.
Rather than simplifying the numerator, you might start by applying the frequency shift rule:
L^{-1}\left[\frac{3-4(s-1)}{(s-1)^2-4}\right]=e^{-t}L^{-1}\left[\frac{3-4s}{s^2-4}\right]
Thanks, I didn't see that at all!
From there I have tried to now split the expression into 2 parts to use the Laplace Transformation table, by doing:
(e^-t)*(L^-1)[3/(s^2 - 2^2)*(L^-1)[-4s/(s^2 - 2^2)]
(e^-t)*[3/2](L^-1)[2/(s^2 - 2^2)*-4(L^-1)[s/(s^2 - 2^2)]
From here I used the two following Laplace transformations:
a/(s^2 + a^2) = sin(at) and s/(s^2 + a^2) = cos(at) to get:
(e^-t)*[3/2]sin(-2t)*-4cos(-2t)
-6(e^-t)*sin(-2t)*cos(-2t)
Not sure if this is right, but it's the best application for the Laplace transformation table for this question I could see.
Why are you multiplying your fractions together like this?
L^{-1}\left[f(s)+g(s)\right]=L^{-1}\left[f(s)\right]+L^{-1}\left[g(s)\right]\neq L^{-1}\left[f(s)\right]*L^{-1}\left[g(s)\right]
Sorry didn't even pick up on that, just a careless error! So it should be:
(e^-t)*[(L^-1)[3/(s^2 - 2^2)-(L^-1)[4s/(s^2 - 2^2)]]
(e^-t)*([3/2](L^-1)[2/(s^2 - 2^2)*-4(L^-1)[s/(s^2 - 2^2)])
(e^-t)*([3/2]sin(-2t)-4cos(-2t))
There are a couple of errors that I missed...
(1) You should have L[y] = \frac{3-4(s-1)}{(s-1)^2+4} not L[y] = \frac{3-4(s-1)}{(s-1)^2-4}
(2) The frequency shift rule does not give exactly what I had posted earlier...can you figure out what it should be?:wink:
