Laser Activated transparent ink?
8 replies · 3K views
jjoll
Hello everyone,
I was just wondering if there is any type of transparent ink that could be permanently activated by heat or intense light (laser).
Preferably I am planning to use a laser light to activate the ink.
I am trying to coat a piece of metal (or paper or etc.) with this ink (which is invisible). Then I want to write on the coating using a laser light. I am supposed to shine a laser beam to the coating in order to draw fine lines/drawings. The laser beam is supposed to activate the ink (reveal its color) as it pass through. The laser is supposed to activate the color of the ink and lock it (meaning, the color is supposed to stay on coating after laser has passes through).
I was just wondering if this is possible and if there is an ink with this kind of characteristic or if I can modify an ordinary ink to behave like this.
Thanks
Chemistry news on Phys.org
jjoll said:
Hello everyone,
Thanks
Can you describe the application?
We have these white hard blocks of foams. Something like these ones:
http://www.cdxghm.com/View_en.aspx?id=123
The idea is to soak the surface of these blocks into our transparent solution (ink/dye + etc) and then use a laser to write/draw on the surface of these blocks and then let them dry.
Why not just use a standard ink jet printer setup?
well let me be more precise. I am working on a college project and directly drawing on the foams is not exactly the point of this project. I am trying to develop a laser printing method in order to use on a sheet of multi-layered photonic crystal. I am going to use these foams to demonstrate a proof of concept to my prof. Imagine these foams to be covered with a thick plastic cover similar to:
https://www.amazon.com/dp/B00L27EPD8/?tag=pfamazon01-20
and we want our laser to go past through this layer and hit the sponge sheet. and write on the foam without damaging the top plastic layer.
I am coming up with these scenarios as I am writing this now. But what I am actually working on is: a sheet of polymer based paper that is made of 4 layers and I am trying to write/engrave on the surface of second layer so the plan is to some how inject the solution to the second layer and then emit the laser from the top (laser is supposed to go past first layer) and then write on the surface of second layer.
jjoll said:
I need a solution (dye/ink/...). Paper is not what I am looking for. thanks
Can't you use the same kind of dyes they use for the paper?
hmm this is really interesting idea. From the wikipedia link that you gave me, I read something about Polaroid ZINK that is used on the thermal papers. this might work. I need to think about this more. thanks
