Is This Method for Laser Cavity Length Calculation Accurate?
The discussion centers on calculating the optical cavity length (L) of a laser using a Michelson interferometer. The participant, Biest, derives the formula 2Ln = d, where d represents the distance between two high amplitude peaks in the interference pattern, and n is the refractive index of silicon (4.01). The response confirms that the formula is accurate, provided that d refers to the total path length difference between the reference arms of the interferometer.
  • Understanding of Michelson interferometer operation
  • Knowledge of optical cavity length calculations
  • Familiarity with fringe pattern analysis
  • Basic principles of laser physics and refractive index
  • Research the concept of Free Spectral Range (FSR) in laser cavities
  • Learn about multimode laser behavior and its impact on interference patterns
  • Explore advanced techniques for measuring optical path length differences
  • Study the effects of different materials on refractive indices in optical systems
Optical physicists, laser engineers, and students studying optics who are interested in precise measurements of laser cavity lengths and interference phenomena.
Biest
Hi,
So I have a lab question for which I have to drive a formula to find the optical cavity length of a laser, L. I have results from testing the fringe patterns when I move one of the mirrors in a Michelson interferometer. It shows the typical \frac{\sin x}{x} pattern. To find the cavity length, I use the distance between two high amplitude peaks, d, and the refractive index of the material inside the cavity, silicon in this case so 4.01. What I did was this, since the distance between peaks is the time between a wave has traveled 2L, I figured that this formula has to be true:
\frac{2Ln}{c} = \frac{d}{c}
which will give me
2Ln = d
Is this accurate?
Thank you very much in advance.
Cheers,
Biest
If I'm inferring what you did in lab correctly, you must have a Michelson interferometer with a variable path length difference (##d##) and you are using a multimode laser as a light source. You scan the interferometer path length difference and you record the intensity of the fringe. As you scan the path length difference of the interferometer, you will find path lengths for which some of the laser modes constructively interfere. The distance between two adjacent laser modes that constructively interfere tells you the FSR of the laser cavity.
If ##d## here means the total difference in path length between the reference arms (as opposed to the difference in mirror position measured relative to the beamsplitter), then yes your formulas are correct: ##2Ln = d##.
  • · Replies 0 ·
