How Does Pump Irradiance Affect Gain in a Four-Level Laser System?
  • Thread starter Thread starter GreenPrint
    Gain Laser
The discussion focuses on determining the pump irradiance required to sustain a small signal gain coefficient of 0.01 cm-1 and the saturation irradiance in a four-level laser system. Key parameters include the effective pump rate density Rp2, which is derived from the transition rates k32, k31, and k30, and the small-signal gain coefficient γ0 defined as γ0 = σRp2τ2. The participant successfully solved the problem by substituting known values into the equations, although they expressed uncertainty about the necessity of the given wavelengths for the solution.
  • Understanding of four-level laser systems and their operation.
  • Familiarity with the concepts of small-signal gain coefficient and saturation irradiance.
  • Knowledge of effective pump rate density and its calculation.
  • Basic grasp of wave properties including phase velocity and angular frequency.
  • Study the derivation and implications of the small-signal gain coefficient γ0 in laser systems.
  • Explore the calculation of saturation irradiance IS in various laser configurations.
  • Learn about the significance of wavelength in laser operation and its impact on gain and efficiency.
  • Investigate the role of spontaneous decay processes in four-level laser systems.
Physicists, optical engineers, and students studying laser technology, particularly those focusing on four-level laser systems and their performance characteristics.
GreenPrint
I'm not sure if this question should be posted in the introductory physics section or the advanced physics section.
Consider an amplifying medium, composed of homogeneous broadening four-level atoms as show in figure 26.5, page 557 of textbook.
http://img689.imageshack.us/img689/6108/lt2f.png
Amplification is to occur on the 2-to-1 transition. The medium is pumped by a laser of intensity I_{p}, which is resonant with the 3-to-0 transition. The spontaneous decay processes are indicated on the diagram. The total number of gain atoms is N_{T} = N_{0} + N_{1} + N_{2} + N_{3}. The various parameters are:
k_{32} = 10^{8} \frac{1}{s}; k_{21} = 10^{3} \frac{1}{s}; k_{10} = 10^{8} \frac{1}{s}; k_{30} = k_{31} = k_{20} = 0
σ_{p} = 4x10^{-19} cm^{2}; σ = 2.5x10^{-18} cm^{2}; λ_{30} = 300 nm; λ_{21} = 600 nm; N_{τ} = 2.0x10^{26} m^{-3}
Assuming an ideal four-level laser system determine:
a) The pump irradiance required to sustain a small signal gain coefficient of \frac{0.01}{cm}
b) The saturation innradiance.
The small-signal gain coefficient γ_{0} and the saturation irradiance I_{S} take the form
γ_{0} = σR_{p2}\tau_{2}
I_{S} = \frac{hv^{'}}{σ\tau_{2}}
R_{p2} is a effective pump rate density
R_{p2} = \frac{κ_{32}}{κ_{3}}(\frac{σ_{p}I_{p}}{hv_{p}}N_{T})
In a closed system
κ_{3} = κ_{32} + κ_{31} + κ_{30}
The lifetime \tau of an energy level is defined to be the inverse of the total decay rate from the level so that
\tau_{n} = \frac{1}{κ_{n}}, n \epsilon Z
Planck's constant h\ =\ 6.62606876(52)\ \times\ 10^{-34}\ J\ s
The phase velocity v_{p} of a wave can be expressed as
v_{p} = \frac{ω_{p}}{k_{p}} ≈ \frac{ω}{k}
k is the propagation constant of a wave that can be expressed as
k = \frac{2\pi}{λ}
Where λ is the wavelength
The angular frequency ω of a wave can be expressed as
ω = 2\pi f
Where f is the frequency
\pi ≈ 3.14
I start off with the equation for the small-signal gain coefficient γ_{0}
γ_{0} = σR_{p2}\tau_{2} [1]
and plug in the equation for R_{p2} effective pump rate density
R_{p2} = \frac{κ_{32}}{κ_{3}}(\frac{σ_{p}I_{p}}{hv_{p}}N_{T}) [2]
into [1].
This yields
γ_{0} = σ\frac{κ_{32}}{κ_{3}}(\frac{σ_{p}I_{p}}{hv_{p}}N_{T})\tau_{2}
I solve this equation for the pump irradiance I_{p} and get
I_{p} = \frac{γ_{0}κ_{3}hv_{p}κ_{2}}{σκ_{32}σ_{p}N_{T}} [3]
I know that for a closed system
Looking at the given variables I get
κ_{3} = κ_{32} + 0 + 0 = κ_{32}
Substituting this into [3] yields
I_{p} = \frac{γ_{0}κ_{32}hv_{p}κ_{2}}{σκ_{32}σ_{p}N_{T}} [3]
Simplifying this yields
I_{p} = \frac{γ_{0}hv_{p}κ_{2}}{σσ_{p}N_{T}} [4]
At this point it looks like I'm very close to solving this problem as all but one variable the phase velocity v_{p} is given. As mentioned in the relevant equations
v_{p} = \frac{ω}{k}
This however doesn't really help me. So there must be some other way of expressing the phase velocity v_{p} that I'm not aware of. Once I figure this out I should be able to solve this problem easily. My book doesn't have any examples in this section and I can't seem to find similar questions on the internet, hence I'm stuck and not really sure how to proceed.
Thanks for any help.
I have just read the caption of the figure and now realize that v_{p}≈\frac{E_{3} - E_{0}}{h}. The only problem now is that I don't know E_{3} or E_{0}. Looks like I might be able to solve this.
I was able to solve the problem. My only concern is that I didn't use the given wavelengths in the problem. Are they needed to solve the problem?
  • · Replies 24 ·
44K
