LASER Problems HELP NEEDED!
  1. May 19, 2010 #1
    LASER Problems!! HELP NEEDED!
    1. The carbon dioxide laser usually emits at 10.6 um in the IR. Typically such a device puts out a continuous emission of from a few watts to several kilowatts. Determine the energy difference in eV between the two laser levels for this wavelength.
    2. A certain variation of He-Ne laser operates btwn two levels that are 3.655 x10^-19J apart. What color is the beam? comupte the wavelength.
    2. Relevant equations
    delta(E)=hc/^
    ^=wavelength
    3. The attempt at a solution
    1. answer is .117eV ..(6.63x10^-34)(3x10^8)/(10.6x10^-6)??but didn't get it
    2. answer is 543.5 nm( green)...3.655 x10^-19J =hc/^
    Please HELP! THanks!
  3. May 19, 2010 #2
    mgb_phys
    Re: LASER Problems!! HELP NEEDED!
    Correct - the energy of a photon is E = h * frequency = h c / wavelenght
    As long as you get the numbers correct in your calculator thats all there is to it - be careful that if 'c' is in metres your wavelength will also be in metres
  4. May 19, 2010 #3
    c=3x10^8 right?
    can you explain more...??tHanks
  5. May 19, 2010 #4
    mgb_phys
    Explain why E = h * frequency ?
    It's rather complex ( see http://en.wikipedia.org/wiki/Planck_constant)
    c = 3x10^8 m/s (remember units matter!)
    h = 6.6x10^-34 Js
    So energy (J) = h (Js) * frequency (1/s), check that the units cancel
    And since speed, c = frequency * wavelength you can rearrange this to give you
    Energy (J) = h (Js) c (m/s) / wavelength (m), again the units cancel out to give you J
  6. May 19, 2010 #5
    I already knew the equation...but I was not sure if I used the right numbers,,,??
    h=6.63x10^-34Js c= 3x10^8m/s
    whatelse??
    thanks
  7. May 19, 2010 #6
    mgb_phys
    For the first part of the problem it asks for the energy in eV
    h = 4.14 x 10^-15 eV s
  8. May 19, 2010 #7
    ahhh got it! THank you! :)
    Can you please answer my other questions??(uncertainty problems?)
