LaTeX Latex Editor Gone? Find Out What Happened
  • Thread starter Thread starter knockout_artist
    Latex
The discussion centers around the absence of a LaTeX editor or equation inserting tool on the forum's editing page, with users expressing confusion about its availability. It is clarified that the forum has not had a dedicated LaTeX editor since migrating to Xenforo over two years ago. Users can still format LaTeX code by using delimiters like double hashtags or double dollar signs. Some users report issues with using LaTeX in their responses, particularly when quoting posts that contain LaTeX. It is noted that mixing BBCode with LaTeX can lead to formatting problems, and users are advised to avoid using BBCode for subscripts or other elements when working with LaTeX to prevent conflicts. Overall, while the LaTeX editor is no longer available, users can still utilize LaTeX formatting through specific coding practices.
knockout_artist
Good Morning,
I don't see latex editor or latex equation inserting tool on the editing page any more, that's when I am creating a thread.
Has any this changed ?
Thank you
Depends on when you last checked. We haven't had a LaTeX editor since we migrated to Xenforo and that was 2.5 years ago. :smile:
Perhaps its called some thing else.
Is the sigma symbol missing from the editor?
sigma button brings back symbols only.
the editor I am speaking of and i have used in past few months would pop open a small window.
In that window it will say "do not use $ $ "
and one editing is done and I press " insert" it will put equation in latex form and it will wrap it in
<tex> \int{a}{b}</tex>.
I am sure I have used it and I am not seeing things :D
I think maybe this was on a different website? We had something like that but it's been a couple years :smile:
I am only member of to math websites.
Other one is not even close to what I am talking about.
Any ways I will try to find one of my old thread and post it here.
thank you.
Even though the post editor does not have a button to insert LaTeX equations, the forum can still format LaTeX code. You just need to delimit your code with double hashtags or double dollar signs. For example:
#.# K_a = \frac{[H^+][A^-]}{[HA]}#.#
becomes
## K_a = \frac{[H^+][A^-]}{[HA]}##
when you remove the period between the hashtags
For more on using LaTeX on the forum see: https://www.physicsforums.com/help/latexhelp/
Likes knockout_artist
I've been here since 2008 or so -- I don't remember ever seeing a LaTeX editor. Everything I do is simple enough that I just insert the script right in the page, similar to what @Ygggdrasil is talking about. For complicated expressions or equations, I hit the Preview button to make sure that my script doesn't have errors.
I think my problem is related to this thread. When I respond to a post with math, I can see LaTex features like '##' being used in the post I am responding to and have quoted, but I can not us it in my answers. I don't see math features in the BBcode guide, so I try LaTex but can not get it into that mode. It's like something in the quote turned it off and I can't turn it back on. What am I missing?
It's not completely clear to me what you're asking, but I'll take a stab anyway.
If you use the Reply button (at the lower right corner of the pane, LaTeX script comes through just fine. Here's a snippet of Yggdrasil's post that I did this on (with most of the text removed later by editing.
becomes
On the other hand, if I just select some text that contains LaTeX script, it gets messed up with lots of extra characters, as below:
Ka=[H+][A−][HA]Ka=[H+][A−][HA] K_a = \frac{[H^+][A^-]}{[HA]}
The workaround is to put the mouse on the expression you want to copy, and right click on it. The menu that appears has Show Math As as the first choice. From that choice, another submenu opens, one option of which is TeX Commands. Clicking that one opens a small window that contains the LaTeX script for the expression you want.
Copy and paste that expression where you want it to go, using a pair of # characters at each end of the script (for inline LaTeX) or a pair of $ characters at each end (for standalone LaTeX.
Here's the result:
@Mark44 , I experimented more and discovered what I was doing wrong. I used BBcode from the editor buttons for subscripts x\[sub\]1\[/sub\] and that prevented the LaTex '#.#' (without the '.') from working.
Like this is no good:
Code:
## y[SUB]1[/SUB] = 2*x[SUB]1[/SUB] #.#  (dot added to suppress LaTex)
So my lesson learned is that I have to be careful about using the editor buttons in an equation if I am going to use LaTex.
##y_1 = 2*x_1##
Right. LaTeX and BBCode don't play well together.
FactChecker said:
##y_1 = 2*x_1##
Or you can do this ##y_1 = 2x_1## or this ##y_1 = 2 \cdot x_1##. In the second equation I used \cdot, which to my eye looks nicer than *.
Likes FactChecker
  • · Replies 23 ·
