LaTeX table woes: It won't grow vertically
  • Topic: LaTeX
  • Thread starter balt
    Latex Table
4 replies · 4K views · last reply
balt
Hi all,
I have an odd problem with a table that refuses to grow vertically, instead, it just wanders off over the righthand edge of the page with each row only one line in height. I have other tables constructed after the exact same method as this one, but they do grow vertically. Confused! Does anyone see what I'm doing wrong?
Code:
\begin{table}
\begin{tabularx}{0.75\textwidth}{lcl}
\toprule
\bf{Component} & \bf{Coefficient} & \bf{Comments} \\
\cmidrule(r){1-3}
RF amplifiers	& 0.04 dB/\textdegree K &  \\
Filters &	0.01 dB/\textdegree K & \\
Ditom	isolator	& 0.005 dB/\textdegree K & \\
Inmet attenuators	& 0.0003 dB/\textdegree K	& This is from theory and the resistor temperature coefficients. The housing and connectors may be somewhat higher than this but in the worst case still $\ll$ 0.001 dB/\textdegree K) \\
DC operational amplifiers & & With high stability resistors, high gain feedback and circuit topology used: $\ll$ than any of the above. \\
DataSet	& & No data is known, however, they were designed and made by xxx and were designed to be at least as stable as the above system. Further to this, the filter data is digitised at the interface to the dataset, it is hence safe to assume that the dataset itself will not have any detrimental effect on the data. It is further located outside the thermal envelope, so any thermal effect it might have will not propagate to the RF components. \\
\bottomrule
\end{tabularx}
\caption{The temperatures coefficients for all components used in the WVR design.}
\label{tab:tempcos}
\end{table}
Thanks for that, I'm a little bit closer!
Forcing the last column to a narrower width does indeed start to grow the table vertically, however, it'll only go to about 7 lines per cell, and it still runs off the end of the page.
there are some truly random thing happening:
Code:
\begin{tabular}{ l c p{3cm} }
Causes the aforementioned effect,
Code:
\begin{tabular}{ p{2cm} c p{3cm} }
Causes the first column to grow to almost half the page width!
Code:
\begin{tabular}{ p{2cm} p{2cm} p{3cm} }
Same, first column takes up almost the entire page (2cm is less than one inch).
Any further suggestions? I'm about to hard wrap those lines. That's a serious shortcoming in LaTeX...
Cheers
- Balt
If you're not using the booktabs package, try just using \hline instead of \toprule and \bottomrule. When defining the column format, p{width} is for paragraph format--since the first two columns aren't blocks of text, I'd suggest leaving them as you had initially, with l and c:
Code:
\begin{tabular}{ l c p{[b]3cm[/b]} }
Except that I'd enlarge the paragraph width (bolded portion) so that you no longer run into the 7-line limitation (say, with 5+ cm).
Unfortunately, my experience isn't extensive with tables in LaTeX, so I'm just going off the previously-linked documentation, as well!
I just found the solution: For whatever reason, the absolue widths were not respected in my tabular environment, so I simply made a mini page in each of the cells that had long text.
Code:
\begin{minipage}[t]{0.6\columnwidth}
\end{minipage}
It's not pretty, but it works.
