High School How Many Layers of Aluminum Foil Are Needed for a Resonant Cavity?
Building a resonant cavity for frequencies around 100-700 MHz using aluminum foil raises concerns about the material's thickness and structural integrity. One layer of aluminum foil may be insufficient, and while skin depth calculations suggest that aluminum could work, issues with seams and the insulating oxide layer complicate its use. Experts recommend using copper foil for better conductivity and suggest that the cavity must be sturdy to maintain resonance. The size of the cavity is also a significant factor, as it varies with frequency, with larger dimensions needed for lower frequencies. Overall, while the material choice is important, mechanical stability is crucial for effective resonance.
kiutukri
I want to build a Resonant Cavity to play with frequencies around 100-700 mhz. I'd like to try different shapes, so I was thinking in using a cheap malleable material like aluminum foil.
Questions:
- I think one layer of aluminum foil might be too thin.. If I paste a couple of layers will do the job?
- How to calculate the thickness?
Many thanks in advance.
so you really want to build a whole bunch of cavities ?
you do realize that a cavity resonant at 100 MHz isn't going to be resonant at 200 MHz, 500 MHz or 700 MHz etc
Do you also realize how big a resonant cavity is at 100 MHz ?
just an approximate ... one for 146 MHz is around 3-4 ft long and ~ 5 inches in diameter
kiutukri said:
so I was thinking in using a cheap malleable material like aluminium foil.
So what were you going to put the foil against for support ? ( one layer from an RF point of view would be ok)
Brass tubes are the commonly used method for cavities. Have used 100's of commercial ones over the years
for VHF - UHF repeater installationsThere's lots of design info on google ... have some fun learning about them :smile:Dave
Hi, Dave,
Thank you for your answer. I'll start building just one then I'll see.
Yes I do realize, that's one of the reasons I want to use a flexible material so I can fold it when I'm not using it. I'm planning to use wood as support, like a canvas frame.
What about my questions?
Thanks.
Very thin. Search "skin depth" and calculate it--you can let us know what you find.
You'll have a much bigger problem with the seams, because of the insulating oxide layer on aluminum. Use copper foil instead and solder the seams to get good conductivity all around.
Likes davenn
yup agree totally ... the inside of the cavity cannot have any breaks in the surface ... it must be electrically continuous
I really don't think that is going to be feasible. The cavities need to be sturdy because any variations will cause changes in the resonance of the cavity
Dave
Hi Marcus,
Thank you for your awesome answer.
I've found this online calculator http://www.rfcafe.com/references/calculators/skin-depth-calculator.htm
According to this, using Copper, for 100 mhz I'll only need a skin depth of: 6.54 μmeters or 257.59 μinches. A thickness of 0.006543 mm sounds totally doable to me.
Even aluminum could do it: 8.19 μmeters, 0.00819 mm. The thickness of a standard aluminum foil is 0.016 mm
I am doing something wrong? o_O
yes, skin depth and the thickness of the aluminium foil isn't a problem and it isn't YOUR problem
Your problem lies in the last part of my last post, which you have yet to acknowledgeDave
Is there any way to calculate that?
why, there's no need ... you already have done so anyway
and as I said, it isn't the problem you need to solve ... you problem is going to be all mechanical
13K
