Laying on the beach while sunseting question
  • Thread starter Thread starter djkinney
12 replies · 8K views
djkinney
Suppose that, while lying on a beach near the equator of a far-off planet watching the sun set over a calm ocean, you start a stopwatch just as the top of the sun disappears. You then stand, elevating your eyes by a height H = 1.58 m, and stop the watch when the top of the sun again disappears. If the elapsed time is t = 10.9 s, what is the radius r of the planet to two significant figures? Notice that duration of a solar day at the far-off planet is the same that is on Earth.
86400 s=1 day
I attempted to solve this by setting the angle, but I think I got the wrong angle. (.0454°)
cos(0.0454°)=((r)/(r+h)) h=1.58
When I solved for the radius I got 1.5e^3, but it is not the right answer. Please help me figure where I went wrong! Thank you!
Hi djkinney,
how did you get the angle?
ehild
ehild said:
Hi djkinney,
ehild
Hey,
Well I'm not quite sure as to how to get the angle. I tried two different ways so far: First, I tried: 10.9s/86400s=1.26e-4°. The second was me trying something crazy and doesn't make any sense: 10.9s*(1min/60s)*(1hr/60min)*(360/24hr)=.0454°
djkinney said:
Hey,
The first method will be all right, but it is not degrees. 1.26e-4 is the ratio to the total revolution, which corresponds to 360 degrees.
ehild
ehild
Okay, so that means that 1.26E^-4*360°=.04536° for the angle? Then I would still be getting my final answer as 1.5E^3
Well, what is that angle and how is it related to the radius of the planet and your height?
ehild
Cos(Angle) = R/(R+1.58)
Angle = 360 * 10.9/(24 * 60 * 60)
Okay, so when I solve for the angle I get .0454°
Then take the cos of the angle in which I get ≈ .9897
Then I set that equal to R/(R+h) h=1.58 → .9897=R/(R+1.58)
Solve for R by multiplying .9897(R+1.58)=R
Then get like terms of one side 1.59=R-R(.9897)
A R can be taken out 1.59=R(1-.9897)
Then I divide 1.59/(1-.9897)=R
R=154m
Is this the correct setup?
I get
R = 1.58 Cos(Angle) / (1-cos(angle))
I make Cos(angle) = 0.9999996858
and
R= 5,029,238 meters
The answer is error prone because the denominator involves subtracting two similar numbers. Might be best to give an answer such as approx 5,000,000 meters?
CWatters said:
I get
and
R= 5,029,238 meters
Wow, I would've never done that. Even my calculus professor didn't tell me that. Thank you so much guys for your help!
Tip: It's usually a mistake to substitute actual values given in the problem until you have rearranged the equations.
The steps I did were..
Cos(angle) = R/(R+1.58)
Cos(angle) * (R+1.58) = R
R*Cos(angle) + 1.58*Cos(angle) = R
1.58*Cos(angle) = R - R*Cos(angle)
1.58*Cos(angle) = R (1 - Cos(angle))
R = 1.58*Cos(angle) / (1 - Cos(angle))
but there might be a shorter way!
I then put the result of Cos(360*10.9/24*60*60) in the memory of the calculator to preserve as many digits as possible while calculating the actual result.
The problems with roundoff error can be removed by using a Taylor series expansion:
1-cosθ ~ θ2/2
I have no preference about length of finding a solution as long as it's the correct one. Thank you so much once again!
