Le chatelier, pressure and volume
  • Thread starter Thread starter Bengo
    Pressure Volume
The discussion revolves around the equilibrium reaction N2O4 ⇔ 2NO2 and the factors affecting its shift. The main question is which change does not cause the reaction to shift to the right. The correct answer is the addition of helium gas at constant volume. The confusion arises regarding changes in pressure and volume, particularly how one can change volume without affecting pressure when the system is at equilibrium. The conversation highlights the importance of considering temperature and the use of a piston to maintain constant pressure while altering volume. It also suggests that understanding reaction quotients and partial pressures is crucial for analyzing such thermodynamic problems. The need to rely on mathematical principles rather than intuitive reasoning is emphasized to navigate these types of questions effectively.
Bengo
This question has been bugging me and the more I think about it the more confused I get.
N2O4 ⇔2NO2
Question: the reaction will shift to the right with all of the following changes except
A. Addition of N2O4
B. an increase in volume at constant pressure
C. A decrease in pressure at constant volume
D. Addition of helium gas to the system at constant volume
I know the answer is D but choice B and C confuse me because with pressure and volume, how can you change one without the other if the reaction is already at equilibrium? I can see if more reactants or products are introduced but the question doesn't say that.
Thank you
Chemistry news on Phys.org
Think what temperature would do to the system and how you can try to control all the variable taking into account the temperature of the system.
Well my book says you can use a piston to keep pressure constant while changing the volume but I just don't understand how that's possible in this particular question when nothing else is being done to the system.
I'm out of practice with these questions but how will you change the volume inside a container (assumed by displacement of a piston) while keeping the pressure, temp and number of mols constant?
Something's got to give, no?
Also keep in mind that in these types of thermodynamics questions you occasionally need to forget the world and let the math do the talking. Are you familiar with the use of a reaction quotient and partial pressures when analyzing these problems?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
