?Learning MCNP for Research Reactor Analysis
The discussion focuses on learning and troubleshooting the MCNP software for research reactor analysis. Participants seek guidance on resources, installation, and specific errors encountered while using the software.
  • Exploratory, Technical explanation, Homework-related
  • One participant seeks recommendations for reading materials and practice resources for MCNP.
  • Another participant suggests starting with the MCNP Primer and the three volumes of the Manual, specifically recommending Volume 2 for detailed study.
  • A participant expresses interest in running basic examples but encounters issues referencing the input file in the MCNP command prompt.
  • Suggestions are made to use VisEd as a visualization tool and to create a batch file for running MCNP commands with specific input and output file names.
  • A participant inquires about the "LCS" error encountered while running a specific input file, asking for clarification on its meaning and how to resolve it.
  • Another participant seeks assistance with executing plot commands in MCNP, expressing confusion over the expected output and encountering errors instead.
  • A participant asks for clarification on the meaning of "R0" in tally F5 for point and ring detectors, requesting examples for better understanding.
The discussion contains multiple competing views and unresolved questions regarding troubleshooting and understanding specific MCNP functionalities. No consensus is reached on the solutions to the errors presented.
Participants express uncertainty about specific error messages and commands, indicating a need for further clarification and examples. The discussion reflects varying levels of familiarity with MCNP and its functionalities.
ISAAC BAIDOO
I just started learning MCNP for research reactor analysis. Can anybody advise where and how I could easily get material to read and practice
Ibrahim Hany said:
For an easy and quick start: Start learning from the Primer.
For a real study with the details, head to the 3 volumes of the Manual. (Start with Vol 2)
Check this: https://laws.lanl.gov/vhosts/mcnp.lanl.gov/mcnp5.shtml
thanks a lot
I have just started and it getting interesting but I tried to run some basic example but i could not reference/direct the MCNP to the inp. file.
for example, how do I start when the mcnp command prompt shows: c:\MCNP>_
You can install the VisEd, it is a good visualizing tool and also you may run on it.
Or you can start a batch file ( in the folder of the input file ) with the command:
MCNP5 (or whatever the version you are using) I=name of the input file with extension O=name of the output file with extension
Dear Sir,
Thank you so much for your eagerness to help.
kindly explain to me the following:
  1. Can you tell me what LCS: error in MCNPX
I got the LCS error prompt from running the input file below:
example 4-3, repeated structure, two cylinders
C cell cards
1 1 9.90605e-2 -1 -4 5 u=3 imp:n=1 $ solution
2 0 -1 4 u=3 imp:n=1 $ void region
3 2 -2.7 1:-5 u=3 imp:n=1 $Al container
4 0 -2 -3 6 fill=3 imp:n=1
5 like 4 but trcl (17 0 0) imp:n=1
6 3 -1.0 10 -11 8 -9 7 -3 #4 #5 imp:n=1
7 0 -10:11:-8:9:-7:3 imp:n=0
C surface cards
1 cz 6.35 $ solution radius
2 cz 6.50 $
3 pz 80.0 $ top of container
4 pz 70.2 $ top of solution
5 pz 0.0
6 pz -0.15
7 pz -20.15 $ bottom of tank
c sides of tank
8 px -16.5
9 px 43.5
10 py -26.5
11 py 26.5
c data cards
c materials cards
m1 1001.62c 6.2210e-2 8016.62c 3.3621e-2
9019.62c 2.5161e-2 92235.66c 1.1760e-2
92238.66c 8.2051e-5
mt1 lwtr.60t
m2 13027.62c 1.0
m3 1001.62c 2 8016.62c 1
mt3 lwtr.60t
c control cards
kcode 5000 1.0 50 250
ksrc 0 0 35 17 0 35
I was trying this example from the mcnp primer, but whiles running, it stopped at the 192nd cycle and indicated “LCS error”
  1. I would want to know how I can execute basic plot command.
The primer indicates I could execute plot command by “mcnp inp=filename ip” or mcnp ip inp=filename. I expect to see the “The default plot is a PX slice centered at (0, 0, 0) with an extent of -100 cm to 100 cm on the Y-axis and -100 cm to 100 cm on the Z-axis” as indicated in the primer. Instead, the is the error comment I get, “bad trouble in mcnpx in routine unique cannpt create outp
In fact, the main problem is how to use the command to display the plot for now before I begin to think about how to make in unique.
Best Regards
Isaac Kwasi Baidoo
can i ask you sir??
Dear Sir,
Sorry sir, i found problem in solving detector flux using tally F5. For tally F5 there is R0 for point and ring detector. I still confuse what’s meaning of R0 ? can you help me to give me some example for make me easy to undestand it?thank you sir,
I hope you help me to solving the problem
  • Sticky
