How to Detect Audio vs. White Noise in RF Circuits?
To detect audio versus white noise in RF circuits, a combination of low pass and high pass filters can be employed, with the crossover frequency set above the audio range. When the output from the low pass filter significantly exceeds that of the high pass filter, it indicates the presence of audio. The outputs can be rectified and compared using a comparator to control an LED, signaling when audio is detected. Additionally, super-regenerative receivers are known for their sensitivity but can produce noise when not receiving a signal, which may allow for a reduction in DC current draw when audio is present. This behavior could potentially be used to mute the audio amplifier in the absence of a signal.
ddcd
I have a question about making an LED light up when sensing audio. Right now, I'm using Super-Regenerative receivers and testing various components of them. Using a signal generator, my audio speaker squeals, as it should, when on the right frequency. When it's not on the right frequency, I hear oscillations (white noise). I did a little research and found one circuit with a comparator and an op-amp.
Basically, does anyone have any ideas on how to detect audio vs. white noise? As in, the signal gets quiet during white noise and is loud when on the right frequency.
It's just highly annoying to myself and my classmates having it squeal all the time.
You could use a low pass filter and a high pass filter with the crossover frequency above the upper end of your audio. When you have significantly more output out of the low pass filter than the high pass, you know you have audio.
The outputs of the two filters could be rectified and compared in a comparator. I would attenuate the low pass filter so that the comparator won't indicate audio unless it is clearly present. Connect the LED to the output of the comparator so that when audio is present, it lights up.
I made some super-regen circuits a long time ago. They are notoriously noisy when they are not receiving a signal, but give amazing sensitivity for simple circuits.
On thing I noticed on mine was that the DC current drawn reduced a lot when it was receiving a signal.
It would be worth finding out if yours is the same. It may be possible to use this effect to mute the audio amplifier when there is no signal being received.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 28 ·
  • · Replies 25 ·
13K
  • · Replies 30 ·
