Lens with different refraction index on each side
The discussion centers on the calculation of the location of a virtual image using a lens with different refraction indices on each side. The formula n1/p + n2/q = -(n2-n1)/R is initially applied, but an error in calculating n2 - n1 leads to incorrect results. After correcting the calculation from 1.3 - 1 to 1.3 - 0.3, the correct virtual image location is determined to be 60.88 cm above the water. Participants confirm the formula's validity while discussing potential sign conventions for R. Overall, the conversation highlights the importance of careful calculations in optics.
JoeyBob
see attached
1/p+1/q=-2/R
So I am not really familiar with lens questions when there's 2 different refraction indexes. I tried using n1/p+n2/q=-(n2-n1)/R but it doesn't seem to work.
p would be the actual location of the fly and q would be the virtual location, what the fish sees if I am understanding correctly. n1 would be the index of refraction where the fly is and n2 where the virtual image is?
So 1/60+1.3/q=-1.3/64. q=-35.155
So the image is 35.155 cm above the water. But this is wrong, the answer is 60.88 cm
The 1.3 on the right side is not correct.
The rest is correct then?
Shouldn't it be on top according to the formula?
The rest is correct.
I'm not sure what you are asking here.
is this formula incorrect here?
The formula looks correct, although I’m not sure what sign conventions you are using for R, etc.
You made a mistake in calculating ##n_2-n_1##.
Likes JoeyBob
ya I am dumb. 1.3-1 isn't the same as 1.3-0. I get q = -60.88 when I use 0.3, so 60.88 above the water.
Thanks.
Likes berkeman
JoeyBob said:
ya I am dumb.
Not at all. We all make slips like this :oldsmile:
Thanks.
Looks good.
