Lenses/Images - Find final image
  • Thread starter Thread starter maniacp08
    Final Image
The discussion focuses on calculating the final image position and overall lateral magnification for a system of two converging lenses, each with a focal length of 8 cm and separated by 35 cm. The initial object is placed 30 cm to the left of the first lens. Using the thin-lens equation, the position of the first image is determined to be 10.37 cm to the right of the first lens. The overall lateral magnification is calculated as -0.79, indicating an inverted image. The user seeks clarification on the final image position and magnification calculations, which were marked incorrect.
  • Understanding of the thin-lens equation
  • Knowledge of lateral magnification concepts
  • Familiarity with ray diagrams for lens systems
  • Basic principles of optics involving converging lenses
  • Review the thin-lens equation and its applications in multi-lens systems
  • Study ray diagram techniques for accurately locating images formed by lenses
  • Explore the concept of overall magnification in systems with multiple lenses
  • Investigate common errors in lens calculations and how to avoid them
Students studying optics, physics educators, and anyone involved in optical engineering or lens design will benefit from this discussion.
maniacp08
Lenses/Images -- Find final image
Two converging lenses, each having a focal length equal to 8 cm, are separated by 35 cm. An object is 30 cm to the left of the first lens.
(a) Find the position of the final image using both a ray diagram and the thin-lens equation
(c) What is the overall lateral magnification?
What I did:
s1' = f1s1/(s1-f1)
s1' = (8cm)(35cm)/(35cm-8cm) = 10.37cm
m1 = - s1'/s = -10.37cm/35cm = -.296285cm
s2' = f2s2/(s2-f2)
s2 = 35cm-30cm = 5cm
s2' = (8cm)(5cm)/(5cm-8cm) = -13.333cm
m2 = - s2'/s = - (-13.333cm)/5cm = 2.666cm
For question a isn't it 35cm+s1'+s2'=32.04cm or 32cm? This answer was marked wrong can anyone tell me what I did wrong?
For question c - m = m1*m2 = -.296285cm*2.666cm = -.78989581cm but this is again wrong
Please help, thanks!
The first image is formed at 10.37cm to the right of the first lens.
This image is now the object for the second lens.
How far is it from the second lens?
  • · Replies 28 ·
