Let ##\forall x,y\in\mathbb{Q}^+## and ##f(xf(y))=\dfrac{f(x)}y##
The discussion revolves around a functional equation involving a function f defined on the positive rational numbers. Participants are exploring properties of f, including injectivity, surjectivity, and multiplicativity, as well as the implications of specific substitutions into the equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants suggest substituting specific values for x and y to derive properties of f. There are discussions about the implications of f being injective and multiplicative, as well as the exploration of whether f can be order-preserving. Some participants question the validity of certain assertions and the existence of such a function.
The discussion is active, with participants providing insights into the properties of f and questioning assumptions. Some have proposed that f is surjective and multiplicative, while others express uncertainty about the existence of such a function and the conditions it must satisfy.
Participants note that the problem involves constraints related to the nature of the function f, including its behavior under multiplication and its bijectiveness. There are references to external sources discussing the properties of automorphisms in the context of the positive rationals.
littlemathquark
User reminded (again) to always show their effort when posting a schoolwork question
Let ##\forall x,y\in\mathbb{Q}^+## and ##f(xf(y))=\dfrac{f(x)}y## so find ##f:\mathbb{Q}^+\to\mathbb{Q}^+##
I have no idea for this question. Can you give me some clue, please?
Have you tried substituting any special values for x or y?
Have you considered a power law relation f(x) = Ax^b?
Yes,
İf ##y=1## then ##f(xf(1))=f(x)## and ##f(1)=1##
for ##x=1## then ##f(f(y))=\dfrac{f(1)}{y}=\dfrac{1}{y}##
Sİnce ##f(xf(y))=\dfrac 1y\cdot f(x)=f(f(y))\cdot f(x)## so ##f## must be multiplicative function so ##f(xy)=f(x)f(y)## and also I found ##f(x/y)=f(x)/f(y)##
littlemathquark said:
Yes,
This doesn't follow. Have you shown that f is injective, so as to justify the assertion that f(xf(1)) = f(x) \Rightarrow xf(1) = x?
So f(x) = x should work. Does it?
##f(y_1)=f(y_2)\implies f(f(y_1))=f(f(y_2))\implies \frac{f(1)}{y_1}=\frac{f(1)}{y_2}\implies y_1=y_2## so f injective.
Yes,
We only have ##f(xy)=f(x)f(y)## for ##x>0## and ##y\in f\left(\mathbb{Q}^+\right).## Is ##f## surjective?
Yes, f is surjective because ##f(f(y)) =1/y## and take ##a/b\in Q^+##
##f(f(b/a)) =a/b##
f(x) =x doesn't work.
##f(f(b/a)) =a/b##
Hence, we are left with the question to determine all automorphisms of ##\left(\mathbb{Q}^+,\cdot\right)## that also fulfill the functional equation. ##f=\operatorname{id}## does not, so we are looking for a proper subset of automorphisms here, and there are no inner automorphisms.
We can also rule out order-preserving automorphisms:
https://www.ams.org/journals/proc/1...-1994-1195720-5/S0002-9939-1994-1195720-5.pdf
Btw., just a question: If you already proved that ##f## is bijective and multiplicative, why don't you tell us before anybody does, or ask about it like @pasmith and me, what you already did? I'm asking this before I test ##f## on its order-preserving property, in case you already did it.
When I asked question I have no idea about it, really. But I have tried to solve it all day and I found what I write to you. So I'm looking for multiplicative and 1-1 and surjective function but I couldn't construct it for now.
The paper says it cannot be order-preserving, and ##q\cdot f^2(q) =1## for all ##q\in \mathbb{Q}^+## suggests it has to be order-reversing since this condition doesn't look as if it can be a wild permutation. Are you sure such a function exists? Maybe we need two different functions depending on whether ##q<1## or ##q>1.##
Here is my solution:
f(x\cdot f(y))=\dfrac{f(x)}{y}
implies that ##f^2(x)=\dfrac{1}{x}## and ##f^4(x)=x## or ##(f^4-\operatorname{id})(x)=0.## Thus
\begin{align*}
(f-\operatorname{id})\circ (f+\operatorname{id})\circ (f^2+\operatorname{id}) =(f^2-\operatorname{id})\circ (f^2+\operatorname{id})=f^4-\operatorname{id}=0
\end{align*}
Since all functions commute with each other, we do not have to care about the order. Now you can solve
(f^2-\operatorname{id})\circ (f^2+\operatorname{id})(x)=\left(\left(\dfrac{1}{\operatorname{id}}-\operatorname{id}\right)\circ \left(\dfrac{1}{\operatorname{id}}+\operatorname{id}\right)\right)(x)=0
which hasn't any solution in ##\mathbb{Q}^+## let alone holds for all positive rationals.
  • · Replies 36 ·
