What happens to the non-interacting part of protons in LHC collisions?
  • Context: Undergrad
  • Thread starter Thread starter Malamala
    Lhc
In proton-proton (pp) interactions at the Large Hadron Collider (LHC), the primary interaction occurs between quarks or gluons from each proton, resulting in particles produced perpendicular to the beam axis, characterized by the transverse momentum (p_T) variable. The non-interacting parts of the protons, including the remaining valence quarks and sea quarks, undergo hadronization, forming jets that travel close to the beam directions. These jets possess lower energy and do not maintain a non-zero electric charge, leading them to interact with the beam pipe or other components downstream. Experiments like LHCf and TOTEM are positioned to detect particles in the extreme forward direction.
  • Understanding of proton-proton interactions in high-energy physics
  • Familiarity with quark and gluon dynamics
  • Knowledge of hadronization processes
  • Awareness of the LHC experimental setup and its components
  • Research the hadronization process in particle physics
  • Explore the role of transverse momentum (p_T) in collider experiments
  • Learn about the LHCf and TOTEM experiments and their findings
  • Investigate the effects of electric fields in lead-lead collisions at the LHC
Particle physicists, researchers in high-energy physics, and students studying collider experiments will benefit from this discussion, particularly those interested in the dynamics of proton interactions and jet formation in the LHC.
Malamala
Hello! I am sorry if this questions is dumb, but in a pp interaction at LHC, as far as I understand, we have one quark or gluon from one proton, interacting with another quark or gluon from the other. This is the main interaction and most of the resulting particles are produced perpendicular to the beam axis, at least for interesting interactions (hence the use of ##p_T## variable). I am not sure I understand what happens to the rest of the 2 protons (the 2 remaining valence quarks and the rest of the sea quarks and gluons). Now they shouldn't be colorless anymore, so they can't stay like that for long. Do they form jets that travel forward, along the beam line? Do they keep going around the beam line for a while (I am not even sure what charge they have). What actually happens to the non-interacting part of the 2 interacting protons? Thank you!
They hadronize and form two jets close to the beam directions, yes. They have a lower energy (but cannot have a lower but non-zero electric charge), so even particles that are nicely aligned with the beam axis won't travel farther than the beginning of the next dipole section. Most of them hit the beam pipe, the shielding, or other elements somewhere downstream. There are some smaller experiments in these regions, LHCf near ATLAS and TOTEM near CMS, to look for particles in the extreme forward direction.
For a while people were concerned about lead-lead operation. If two lead nuclei pass each other closely (without colliding) the electric field is so strong that you can produce electron/positron pairs and one of the electrons can stick to a nucleus. You would produce a set of Pb81+, all with the same momentum as the fully ionized Pb82+, so these lead ions could all hit the accelerator wall in the same spot, potentially damaging it. As operation showed this is not a big deal.
  • · Replies 16 ·
  • · Replies 23 ·
