Light Diffraction physics problem
6 replies · 1K views · last reply
Tkdmaster
You have project in your physics class to build a diffraction grating. The key component is that you need to disperse visible light over a 30-degress spread at the first order. Visible light has a range of 400-700nm. How many lines per mm do you need for your diffraction grating?
mλ =dsin(Θ)
Been trying to figure this problem out for a couple hours now, if i use 400 nm into the equation it comes out to 800: 400=sin(30). If i do 700 nm it comes out to 1400: 700=sin(30).
I feel like i’m doing somethingwrong with the problem but i can’t figure out what.
This means that the difference between the diffraction angles for 400 nm and 700 nm needs to be 30°, not that either of those angles needs to be 30°. For example (just making up numbers here!) you might end up with something like θ = 22° for λ = 400 nm and θ = 52° for λ = 700 nm, for a spread of 52° - 22° = 30°.
The thing is though, i don't know how to determine what those angles would be.
Suppose you choose a spacing d. Through what angles will the extremes of visible light be diffracted (to the first order)?
Call the extreme wavelengths ##\lambda_1## and ##\lambda_2##. They diffract through angles ##\theta_1## and ##\theta_2##. Can you write an equation that gives the spread in angles, ##\theta_2 - \theta_1##, in terms of ##\lambda_1##, ##\lambda_2##, and ##d##? That is, ##\theta_2 - \theta_1 = \cdots##
No, you can't do it by simply substituting ##\theta_2 - \theta_1## for ##\theta##, and ##\lambda_2 - \lambda_1## for ##\lambda##.
Start with your diffraction equation ##\lambda = d \sin \theta##. Solve it (rearrange it) to get a new equation ##\theta = \cdots##.
Now, using your numbers, you actually have two of these equations: ##\theta_1 = \cdots## and ##\theta_2 = \cdots##. Subtract one from the other to get ##\theta_2 - \theta_1 = \cdots## with ##d## somewhere on the right-hand side.
