Light interferometry as described in Thorne's black holes and time warps ?
The discussion centers on the principles of laser interferometry as described in Kip Thorne's "Black Holes and Time Warps." A participant questions Thorne's assertion that waves reaching the photodetector interfere destructively, while those returning to the laser source interfere constructively. The explanation clarifies that the beam splitter plays a crucial role in determining the phase of the beams, leading to destructive interference at the photodetector and constructive interference at the source. Understanding the phase shifts caused by the beam splitter is essential for grasping the interference patterns in this system.
  • Understanding of laser interferometry principles
  • Familiarity with beam splitter functionality
  • Knowledge of wave phase shifts and interference
  • Basic concepts of gravitational wave detection
  • Study the operation of beam splitters in optical systems
  • Learn about wave interference patterns in laser systems
  • Explore the mathematical modeling of phase shifts in interferometry
  • Investigate gravitational wave detection technologies and their principles
Physicists, optical engineers, and students of gravitational wave research will benefit from this discussion, particularly those interested in the intricacies of laser interferometry and its applications in detecting gravitational waves.
matteo210
light interferometry as described in Thorne's "black holes and time warps"?
hello,
maybe someone who read the book can help me with this, but i'll give all the information so that even someone who hasn't read it can understand.
At page 383 and following, and at fig. 10.6 and box 10.3, Thorne describes the basic functioning of a laser interferometric gravitational wave detector. My question is not relative to the "gravitational" part but only to the laser interferometry. In the box and in the figure (link below), Thorne writes that the "waves" reaching the photodetector interfere destructively while the "waves" reaching back the laser/emitter/source interfere constructively. Shouldn't it be the opposite? i was thinking that the "waves" reaching the photodetector, traveling the same distance in space at the same time, (both being reflected twice and passing thru the mirror once), would interfere constructively. Why Thorne writes the opposite instead?
For anyone who has not access to the book, i found this site which has a picture similar to the one in the book
http://plus.maths.org/issue18/features/thorne/
it's the drawing rapresenting laser interferometry. In the book Thorne writes that there should be no light in the photodetector due to destructive interference. Why it is not the opposite (all the light in the photodetector due to costructive interference)?
thanks
Moderator's note: Thread moved to relativity forum.
You're leaving out a key component of the system: the beam splitter. The laser light comes from the source, goes through the beam splitter, travels out the two arms, gets reflected, travels back, and reaches the beam splitter again. If the arms are exactly the same length, then what happens is that the beam "splitter" just functions as a beam "recombiner"--it just combines the two split beams back into one beam that is traveling in the direction it originally came from--i.e., towards the laser source. That's because the beams coming back are just the exact reverse of the beams going out, so going back through the beam splitter just reverses the splitting and sends all the light back to the source (as long as the arm lengths have stayed the same).
Thorne phrases it in terms of constructive and destructive interference, but he's really saying the same thing as the above. If you want to break it down in more detail, you need to consider each step in the process and take into account what the beam splitter does. So to start, we have a beam coming from the laser source and being split at the beam splitter into two beams: one beam goes straight through and is unchanged, and the other gets reflected by 90 degrees and has its phase reversed (i.e., shifted by 180 degrees). Call the beam that goes straight through from the laser source beam A, and the beam that gets reflected by 90 degrees beam B.
Now the beams each travel out their respective arms, get reflected, and come back along the two arms and pass through the beam splitter again. Beam A now gets split into a part that goes straight back to the laser detector with its phase unchanged, and a part that gets reflected by 90 degrees and goes towards the photodetector; but the reflected part also has its phase unchanged, because reflection only changes the phase on the front side of the beam splitter (the side facing the laser source), not the back side (the side facing the arm beam A travels along). Beam B also gets split into a part that goes straight through to the photodetector, and another part that gets reflected by 90 degrees; and since this reflection is off the front side of the beam splitter, it shifts the phase by 180 degrees.
So on the laser source side, we have the part of beam A that went straight through both times with phase unchanged, and the part of beam B that got reflected twice with a phase shift of 180 degrees each time. So the two are in phase and interfere constructively.
But on the photodetector side, we have the part of beam A that got reflected once off the back side of the splitter, so its phase is unchanged, and the part of beam B that got reflected once off the front side of the beam splitter, so its phase got shifted by 180 degrees. So the two are 180 degrees out of phase and interfere destructively.
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 16 ·
