Undergrad Light-Like Separation: Is It Possible?
  • Thread starter Thread starter novice_hack
    Separation
The discussion centers on whether all events in a field can be light-like separated in the context of relativity. It clarifies that events are points in the space-time manifold and that a field is a function of these events. The concept of light-like separation implies that events can only be connected by light-like geodesics, but introducing additional events not on that trajectory leads to space-like or time-like separations. The ambiguity of spacetime intervals in non-flat space-time is also highlighted, emphasizing the need for a defined path between events. Ultimately, the question of light-like separation is deemed poorly formed without specifying the path involved.
novice_hack
Is it possible for all the events in a field to be light-like separated from each other? What would such a field be like?
What do you mean by "events in a field"?
Events in relativity are points of the space-time manifold. A field is a function of events, ##f(x)## (where ##f## can be all kinds of quantities, scalars, vectors, tensors, or various kinds of spinors or also operators of all these kinds when it comes to QFT, and ##x## are coordinates, ##(x^0,x^1,x^2,x^3)##).
Likes martinbn, Nugatory and Ibix
Ok. I suppose I meant: can all the spacetime intervals between events be light-like?
The set of events comprising a light-like geodesic would have that property.
However, if you included any additional event not on that trajectory then it seems clear that such an event would have space-like separation from some events on the trajectory and a time-like separation from others.
Note that you must be talking about flat space-time since the "spacetime interval" between events is ambiguous otherwise.
Likes vanhees71 and Ibix
The spacetime interval is defined along a path. It requires more than just specifying a pair of events. It requires specifying the path from one to the other. So the question really is not well formed.
Likes cianfa72 and vanhees71
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 53 ·
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 40 ·
