Light - stopped or trapped inside a crystal?
  • Context: Graduate
  • Thread starter Thread starter San K
    Crystal Light
The discussion revolves around the behavior of light in a crystal, specifically whether light is stopped or trapped within an opaque crystal of yttrium silicate doped with praseodymium. Participants explore concepts related to quantum memory, the preservation of quantum coherence, and the effects of different media on the speed of light.
  • Some participants question whether light is truly stopped or merely trapped, suggesting that it may be internally reflecting within the crystal.
  • There is a query about whether quantum coherence is maintained while the photon remains inside the crystal.
  • One participant mentions that light is slowed in water due to absorption and re-emittance, raising questions about the mechanisms involved.
  • Another participant refers to the concept of electromagnetically induced transparency (EIT) to clarify aspects of the discussion, stating that light cannot be stopped in the way initially proposed.
  • It is noted that the slowing and stopping of light pulses depend on the dispersion profile of the medium, with steep slopes affecting group velocity.
  • A participant introduces the term "polariton," describing it as a coupled system of a photon and a material excitation, and explains that stopped light occurs when all energy is converted into the material.
  • There is a question about the duration for which converted energy can be held in the material before being re-converted back into a photon, with a response indicating that this depends on the coherence time of the material.
  • Specific examples of rare-earth elements are mentioned, such as praseodymium and europium, with differing theoretical coherence times.
Participants express differing views on whether light is stopped or trapped, and the discussion remains unresolved regarding the implications of quantum coherence and the mechanisms of light behavior in different media.
Participants reference specific experiments and theoretical concepts, but there are limitations in the assumptions made about coherence times and the definitions of stopping versus trapping light.
San K
Light -- stopped or trapped inside a crystal?
In the below experiment:
http://www.extremetech.com/extreme/...-inside-a-crystal-the-basis-of-quantum-memory
Opaque crystal of yttrium silicate doped with praseodymium1. Is light stopped or trapped (i.e. internally reflecting, bouncing off the "walls")?
2. Will quantum coherence be preserved as long as the photon stays inside the crystal?
3. Is light "slowed" in water because of absorption and re-emittance of the photon?
I'm bumping this thread in hopes that somebody has an answer regarding this experiment. Thanks!
San K,
Read the Wikipedia article on Electromagnetically induced transparency. You will see that the answer to your question 1 is no. The answer to question 2 is yes. As far as question three goes; when light passes from a medium of lower refractive index to a medium of higher refractive index, the group velocity slows down. This is a completely different optical process from EIT.
With regards to your specific question f.wright above me answered it correctly, but I can still expand on these results a bit.
Slowed and stopped light of pulses happens when the dispersion profile contains very steep slopes, as the group velocity of a pulse inside a medium depends on the derivative of the group refractive index with respect to frequency. In addition, one can see that while the pulse is being slowed down by this effect, an increasing part of its energy is actually stored in the material. A kind of pseudoparticle is formed, called a polariton, which is a coupled system of a photon and a material excitation. Stopped light is a special case when all of the energy has been converted into the material. Hope that makes things a bit more clear.
Thanks Zargon, f.wright and coktail.
Good introduction to the term "polariton"
can the converted energy be held (in the material) for upto to, say, an hour and then later re-converted back as a photon? ...that emits out of the material
Yes, in principle it can, it depends on the coherence time of the material. In the quoted paper, the hyperfine levels of Praseodymium is used, which have a max of about 1 minute, which they reach. But there are other rare-earth elements which can be used as well, for example Europium where the theoretical coherence time is several days.
