Can a Dragon Direct Lightning If It Can't Create an Opposite Charge?
A dragon capable of generating electrical charges would need to create an opposite charge at its target to direct a lightning-like discharge. If a person is on an insulating surface, such as rubber or EPDM, they may be immune to this discharge, as the insulator would prevent the flow of electricity. Alternatively, hiding in a Faraday Cage would provide protection by channeling any electrical energy around the individual. The dragon, while flying, would likely strike taller conductive objects preferentially, making insulated individuals less likely to be targeted. In a vacuum, it is possible to direct a beam of electrons, allowing for more precise targeting. The discussion incorporates elements of both fantasy and physics, suggesting a blend of creative storytelling with scientific principles.
RJ Ashby
Okay- first off, I know enough science to sound like an idiot, so please be gentle :-)
Now, IF you had a dragon that generated an electrical charge, it wouldn't be able to direct it, lightning-style, without being able to generate an opposite charge at it's target- right? So in essence, to shot a bolt of lightning, the dragon would have to create a charge in the ground or on it's target, and charge itself at the same time- right?
If the above is right, then would a target, particularly a person, sitting on a rubber or EPDM sheet, be immune to this discharge?
Or alternatively, would the target be best to hide in a Faraday Cage?
This is all for a post-apocalypse sci-fantasy sort of thing, so I don't mind rewriting some rules of physics, but not outrageously so.
Thank you so much in advance!
It flies, it picks up plenty of static charge ---- remember the scene in Red October?
RJ Ashby said:
post-apocalypse
Plenty of gamma sources around, build those into the beast's diet/metabolism in some sort of lead shielded tonsils. Open mouth leak a little gamma radiation along path to target, ionizing enough air to start the static discharge, and blast. Could be made plausible.
There's a thread in Classical Physics about lightning and automobiles discussing just this point.
Excellent- very handy info to get started with! Thanks
Check this out for some lightning dynamics.
Assuming the dragon is flying, the lightning will preferentially hit taller conductive objects.
Both people on insulators and people in cages would be protected to some extent. The former would not likely get targeted, and the latter would channel the energy around the person. The dragon wouldn't really be able to aim.
This is the behavior in a strongly collisional regime. In a weakly collisional regime, such as a near vacuum, you can get a beam of electrons, as in a cathode ray, and you can direct the beam in any direction you want.
Very useful- thank you!
Recently, I’ve heard from Anton Petrov on YouTube that some tidally-locked planets around red-dwarf stars (such as TRAPPIST-1) have been suspected to flip around their own axis every once in a while — so that the former day side becomes the night side, and vice versa. This is presumed to happen for the same reason as why a T handle set in a rotating motion on a space station starts flipping back and forth. The latter is an issue we discussed for spaceship designs, when it came to how...
