Salles
- 1
- 0
Why isn't the sky violet? Since violet has a shorter wavelength even than blue, why doesn't it dominate then?
Part of the reason is that violet is not a spectral hue. Wavelengths shorter-than-blue (ultraviolet spectra) are indeed scattered more than blue, but your photoreceptors don't respond to UV. "snow blindness" occurs from the large amount of UV light scattered from ice/snow.Salles said:Why isn't the sky violet? Since violet has a shorter wavelength even than blue, why doesn't it dominate then?
We don't see violet very well. But if you are not careful, I will start into a discussion of "indigo" as a color and whether our perception in this region is because of the odd color response as indicated in the CIE standard curves. I find it interesting (consider this a threat !)Drakkith said:What do you mean? Violet is 'spectral' as much as blue is if I'm not mistaken.
Hold your fire! I just want to know what Andy means by 'spectral hue'!hutchphd said:We don't see violet very well. But if you are not careful, I will start into a discussion of "indigo" as a color and whether our perception in this region is because of the odd color response as indicated in the CIE standard curves. I find it interesting (consider this a threat !)
Andy Resnick said:Alternatively, the electromagnetic spectrum does not contain purples/violets
I'm assuming this is a joke?hutchphd said:But it is listed in the official acronymic name "Roy G.Biv".
So it must be a color, 'cause that is the officially recognized acronym.
Violet is absolutely a spectral color, meaning that it can be generated with a small, continuous section of the EM spectrum. Wavelengths from about 380 - 435 nm are generally considered to be in the violet range of the spectrum.Andy Resnick said:I mean that no points on the violet-purple line on the CIE chromaticity diagram correspond to electromagnetic frequencies. Alternatively, the electromagnetic spectrum does not contain purples/violets (or pinks and browns, for that matter...)
I would prefer to call it hyperbole.Andy Resnick said:I'm assuming this is a joke?
Violet is absolutely a spectral hue. I have a 405nm laser pointer, and it is absolutely, 100% violet (and anyone looking at it would describe it that way, though it's also kinda wild to see because you don't see pure light in that frequency range that often - most monitors and displays are completely incapable of replicating it). Purple and magenta is non-spectral, as it requires a mixing of blue/violet and red, but violet is recognizable and producible by a single light frequency in the low-400nm range.Andy Resnick said:I mean that no points on the violet-purple line on the CIE chromaticity diagram correspond to electromagnetic frequencies. Alternatively, the electromagnetic spectrum does not contain purples/violets (or pinks and browns, for that matter...)
cjl said:Violet is absolutely a spectral hue. I have a 405nm laser pointer, and it is absolutely, 100% violet (and anyone looking at it would describe it that way, though it's also kinda wild to see because you don't see pure light in that frequency range that often - most monitors and displays are completely incapable of replicating it). Purple and magenta is non-spectral, as it requires a mixing of blue/violet and red, but violet is recognizable and producible by a single light frequency in the low-400nm range.
If the hue is generated by a continuous section of the EM spectrum, it's not a pure spectral color- by definition.Drakkith said:Violet is absolutely a spectral color, meaning that it can be generated with a small, continuous section of the EM spectrum. Wavelengths from about 380 - 435 nm are generally considered to be in the violet range of the spectrum.
Purple, on the other hand, is not a spectral color. It is a mix of red and blue.
Then you would disagree with everyone I've shown it to.Andy Resnick said:I wouldn't- that wavelength simply appears as an intense blue to me. This diagram is pretty clear- violet does not correspond to an electromagnetic frequency.
https://www.ledtronics.com/html/1931ChromaticityDiagram.htm
There's often a lot of noisy "discussion" about color due to lack of attention to how photoreceptors and brain work. In my experience, the noisiest people are those that never considered color blindness.
That's fine- I am color-blind, after all. How about this- given the sensitivity curves of human cone cells, explain how red hues are is perceived when the retina is excited by 405 nm light:cjl said:Then you would disagree with everyone I've shown it to.
Yeah, yeah.... whatever. Bees see 'ultrayellow'.cjl said:There's a reason we call shorter wavelength light "ultraviolet" and not "ultrablue".
I don't see anything on that chart that says that violet does not correspond to an EM frequency.Andy Resnick said:I wouldn't- that wavelength simply appears as an intense blue to me. This diagram is pretty clear- violet does not correspond to an electromagnetic frequency.
Forgive me, I was being too precise. There are no single-wavelength light emitters in real life, not even lasers, so I was trying to be as accurate as possible. I should have simply said 'single wavelength'.Andy Resnick said:If the hue is generated by a continuous section of the EM spectrum, it's not a pure spectral color- by definition.
The graph is probably wrong, that's why.Andy Resnick said:That's fine- I am color-blind, after all. How about this- given the sensitivity curves of human cone cells, explain how red hues are is perceived when the retina is excited by 405 nm light:
https://askabiologist.asu.edu/sites/default/files/cones_graph.gif
The reason this is tricky stems IMHO from the fact that the "red" CIE response curve has two humps. One of them is in the violet . I believe this drives the other CIE color mapAndy Resnick said:This diagram is pretty clear- violet does not correspond to an electromagnetic frequency.
https://en.wikipedia.org/wiki/Violet_(color)#OpticsWikipedia:
Violet is at one end of the spectrum of visible light, between blue light, which has a longer wavelength, and ultraviolet light, which has a shorter wavelength and is not visible to humans. Violet encompasses light with a wavelength of approximately 380 to 435 nanometers. Violet objects often appear dark, because human vision is relatively insensitive to those wavelengths.[citation needed] The reason that to (typical trichromat) humans violet light appears a bit reddish compared to spectral blue (despite spectral red being at the other end of the visible spectrum) is because the S-cone type (i.e. the one most sensitive to short wavelengths) contributes a bit of red to the red-versus-green opponent channel (which at the longer blue wavelengths gets counteracted by the M-cone type).[19] Computer and television screens, using the RGB color model, cannot produce actual violet light and instead mimic it with a shade of purple, combining blue light at high intensity with red light at less intensity.
Huh- I'll be a monkey's uncle, you are right! I found this reference, very careful measurements:Drakkith said:The graph is probably wrong, that's why.
In fact, the number of different graphs on the response of cone cells is high enough that I don't know which ones to believe. Here's a few I quickly found from google images, all different:
