LIGO & Special Relativity: Is Spacetime Distortion Real?
The discussion clarifies that the LIGO experiment, which detects gravitational waves, does not confirm the existence of length contraction in objects in motion as predicted by special relativity (SR). Length contraction is not related to spacetime distortion caused by gravitational waves. While some historical experiments, such as the Michelson-Morley experiment and cosmic ray muon observations, imply length contraction, no direct tests have been conducted on macroscopic objects. The distinction between direct and indirect tests of length contraction remains a topic of debate among physicists.
  • Understanding of special relativity concepts, particularly length contraction
  • Familiarity with gravitational waves and the LIGO experiment
  • Knowledge of the Michelson-Morley experiment and its implications
  • Awareness of the rod-and-barn paradox in relativity
  • Research the implications of the Michelson-Morley experiment on special relativity
  • Study the concept of gravitational waves and their detection methods using LIGO
  • Explore the rod-and-barn paradox and its significance in testing length contraction
  • Investigate the experimental basis of special relativity and its historical context
Physicists, students of relativity, and anyone interested in the implications of gravitational waves and length contraction in modern physics.
zoltrix
Hello
Is the distortion of spacetime by gravitational waves directly related to the contraction of objects in motion predicted by special relativity ?
In other words
Besides the existence of the gravitational waves , did the LIGO experiment definitely confirm the contraction of the bodies in motion which had never been observed so far ?
No. SR length contraction involves no "distortion of spacetime" at all.
No. See above.
Lorentz certainly believed that Michelson and Morley had observed it. I tend to agree with him on that point.
zoltrix said:
... the contraction of the bodies in motion which had never been observed so far ?
It's worth googling for "purcell magnetism length contraction"
At least some sources (e.g. the experimental basis of SR FAQ linked from this forum) do say that there have been no direct tests of length contraction. They mean that we've never actually carried out the rod and barn paradox experiment, and never imaged something moving fast enough that we'd expect to see length contraction. But there are many experiments that have been carried out that require length contraction for their interpretation - for example the cosmic ray muons, as well as the Michelson-Morley experiment and Purcell's explanation of the field around a current carrying wire already mentioned by others.
LIGO does not have anything to do with length contraction. Length contraction is closely related to the fact that a cylindrical rod, sliced diagonally, has an elliptical cross-section. A 3d slice (what we call "an object, now") through a 4d worldtube has a different shape depending on the angle between the worldtube and your definition of "now" - i.e., the object's velocity relative to you. This is a completely separate phenomenon from the specific type of curvature of spacetime which we call gravitational waves.
Where "direct" is a matter of convention. One could argue that all measurements we make are indirect. Is the point that length contraction was not tested for macroscopic objects?
That's my reading of it, yes - we haven't done the rod-and-barn paradox scenario in practice. As you say, the distinction between a "direct" and "indirect" test is arguable, but at least some respectable sources do phrase it that way.
  • · Replies 37 ·
  • · Replies 19 ·
  • · Replies 83 ·
