Limit of a function in two variables
The discussion revolves around proving the limit of a function in two variables, specifically the limit as \((a,b)\) approaches \((0,0)\) for the expression \(\frac{\sin^{2}(a-b)}{\left|a\right|+\left|b\right|}\). Participants are exploring the application of the \(\epsilon-\delta\) definition of limits in this context.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various attempts to apply the polar conversion and the \(\epsilon-\delta\) framework. There are questions about how to manipulate inequalities and the relationship between \(\epsilon\) and \(\delta\). Some participants express confusion about the order of proving \(\delta\) given \(\epsilon\) and seek clarification on how to construct their proofs.
There is an ongoing exploration of different approaches to the problem, with participants sharing their attempts and questioning the validity of their reasoning. Some guidance has been offered regarding the use of inequalities and the triangle inequality, but no consensus has been reached on a specific method or solution.
Participants are working within the constraints of homework guidelines, which may limit the methods they can use. There is also a focus on ensuring that the reasoning aligns with the formal definition of limits, which adds complexity to their discussions.
Misirlou
Prove with [itex]\epsilon-\delta[/itex]: [itex]Lim_{(a,b)\rightarrow(0,0)}\frac{sin^{2}(a-b)}{\left|a\right|+\left|b\right|}=0[/itex]
Hint: [itex]\left|sin(a+b)\right|\leq\left|a+b\right|\leq\left|a\right|+\left|b\right|[/itex]
[itex]0<\sqrt{(x-x_{0})^{2}+(y-y_{0})^{2}}<\delta[/itex]
and
[itex]\left|f(x,y)-L\right|<\epsilon[/itex]
I tried the polar conversion, which was just messy and got me nowhere. Then I tried inputting for [itex]\epsilon-\delta[/itex] formula: [itex]0<\sqrt{x^{2}+y^{2}}<\delta[/itex] and [itex]\frac{sin^{2}(a-b)}{\left|a\right|+\left|b\right|}-0<\epsilon[/itex] so that [itex]sin^{2}(a-b)<(\left|a\right|+\left|b\right|)\epsilon[/itex]
The tutorials I've seen use the [itex]\epsilon[/itex] inequality and transform it into the [itex]\delta[/itex] inequality, but I don't know how to do this. I'm just looking for a way to solve it, not necessarily using the "hint".
Misirlou said:
Prove with [itex]\epsilon-\delta[/itex]: [itex]Lim_{(a,b)\rightarrow(0,0)}\frac{sin^{2}(a-b)}{\left|a\right|+\left|b\right|}[/itex]
and
The hint appears to be very useful here.
If [itex]\left|\sin(a+b)\right|\leq\left|a+b\right|\leq \left|a\right|+\left|b\right|[/itex],
then [itex]\left|\sin(a-b)\right|[/itex]
[itex]=\left|\sin(a+(-b))\right|\leq\left|a+(-b)\right|\leq\left|a\right|+\left|-b\right|[/itex]
               [itex]=\left|a\right|+\left|b\right|[/itex]​
Okay, that makes more sense. So if [itex]sin^{2}(a-b)\leq sin(a-b)\leq\left|a\right|+\left|b\right|[/itex]
Then
[itex]\left|a\right|+\left|b\right|<\left|a\right|+\left|b\right|\epsilon[/itex]
So
[itex]1\leq \epsilon[/itex]
However, I've been taught to solve for [itex]\delta[/itex] first, and then prove with Given [itex]\epsilon>0[/itex] and Choose [itex]\delta= constant*\epsilon[/itex]. Now if I have [itex]\epsilon[/itex] first, how do I construct a proof this way ?
Any guidance is appreciated :)
Then
So
That basically shows that [itex]\displaystyle \frac{\sin^{2}(a-b)}{\left|a\right|+\left|b\right|}\leq1[/itex] no matter what the value of δ .
But you need to find a δ so that [itex]\displaystyle \frac{\sin^{2}(a-b)}{\left|a\right|+\left|b\right|}\leq\varepsilon[/itex], whenever [itex]\displaystyle 0<\sqrt{a^2+b^2}<\delta\,.[/itex]
I'm not sure how I can go about that. Where should I start looking for a delta ?
Well, you know that [itex]\displaystyle \left|\sin(a-b)\right|\leq\left|a \right|+\left|b\right|\,,[/itex]
so [itex]\displaystyle \frac{\sin^{2}(a-b)}{\left| a\right|+\left|b\right|}\leq\left|a\right|+\left|b\right|\ .[/itex]
And as is usually done, start with ε and \work your way to δ.
Then for the proof you write-up, reverse the order.
Typo fixed in Edit.
Okay, so this is where I am. [itex]0\leq\sqrt{a^{2}+b^{2}}^{2}\leq\delta^{2}[/itex]
So
[itex]0\leq\left|a^{2}+b^{2}\right|\leq\delta^{2}[/itex]
and because
[itex]\left|a^{2}+b^{2}\right|\leq \left|a^{2}\right|+\left|b^{2}\right|[/itex]
Then
[itex]0\leq\left|a^{2}\right|+\left|b^{2}\right|\leq\delta^{2}[/itex]
and I would somehow slide in that
[itex]\frac{\sin^{2}(a-b)}{\left|a\right|+\left|b\right|}[/itex]≤[itex]\left|a\right|+\left|b\right|[/itex]
I feel like I could use the triangle inequality: [itex]\left|a\right|+\left|b\right|\geq \sqrt{a^{2}+b^{2}}[/itex]
but I am I allowed to squeeze it in between the [itex]\sqrt{a^{2}+b^{2}}[/itex]and δ?
because I've so far only squeezed stuff in between [itex]\sqrt{a^{2}+b^{2}}[/itex] and 0
So
and because
Then
[itex]0\leq\left|a^{2}\right|+\left|b^{2}\right|\leq \delta^{2}[/itex]
Can you show that [itex]\displaystyle 2\sqrt{a^2+b^2}\ge\left|a\right|+\left|b\right|\ ?[/itex]
