Finding the Limit of a Multi-Variable Function
To find the limit of the function lim(x,y)->(0,0) x²sin²y/(x²+2y²), users suggest exploring different paths to the origin to determine if the limit exists or not. One method involves substituting x=y or x=0, but results may vary. Another recommended approach is using polar coordinates to analyze the behavior as the distance from the origin approaches zero. The discussion emphasizes the importance of testing multiple paths and bounding techniques to confirm the limit's existence. The expression is believed to approach zero, but verification is needed.
hazellaw
i need some help with this question
Find the limit, if it exists, or show that the limit does not exist
lim(x,y)->(0,0) x2sin2y/(x2+2y2)
i've tried to x=y x=0 or x=y2 but i still got 0...
With these kind of exercises, there are two alternatives:
It could be that the limit does not exist, and then you can prove it by finding two different paths to the origo, such that the limit is different along them.
Or then, it could be that the limit does exist,and then a one good idea is to use polar coordinates, or in some other way obtain some bounds (upper or lower, whatever you need) as a function of r (distance from origo), and then prove that the bounds converge when r\to 0.
If you don't know in advance what the correct solution is, then you must try both to see what works.
I believe this expression approaches zero when (x,y)\to 0, but it could be I made mistake.
Hi hazellaw! :smile:
Can you see an easy way of doing it for x2sin2y/(x2 + y2) ?
Then adapt that. :wink:
