Limit proofs(indeterminate forms?)
  • Thread starter Thread starter mynameisfunk
    Forms Limit
The discussion revolves around the convergence of series and the implications of certain conditions on their terms. It examines whether the convergence of series like ∑a_n^4 guarantees the convergence of ∑a_n^5 and ∑a_n^6, with participants noting that comparisons are necessary since the terms are not guaranteed to be non-negative. The conversation highlights confusion regarding the behavior of sequences and series, particularly concerning the conditions under which na_n approaches 0 as n approaches infinity. Participants emphasize the importance of understanding the nth term test for divergence and the limitations of the root test in determining convergence. Overall, the thread focuses on clarifying misconceptions about series convergence and the necessary proofs or counterexamples for each statement.
mynameisfunk
limit proofs(indeterminate forms??)
We work in the real numbers. Are the following true or false? Give a proof or counterexample.
(a) If \sum a^4_n converges, then \sum a^5_n converges.
(b) If \sum a^5_n converges, then \sum a^6_n converges.
(c) If a_n \geq 0 for all n, and \sum a_n converges, then na_n \rightarrow 0 as n \rightarrow \infty.
(d) If a_n \geq 0, for all n, and \sum a_n converges, then n(a_n - a_{n-1}) \rightarrow 0 as n \rightarrow \infty.
(e) If a_n is a decreasing sequence of positive numbers, and \sum a_n converges, then na_n \rightarrow 0 as n \rightarrow \infty.
(a) and (b) can be proved similarly. Since \sum a_n^4 converges, for some N, when n \geq N, then a_n^4 < 1. Take \beta s.t., a_n^4 < \beta < 1. That is, a_n < (\beta)^{1/4} < 1. Also, |(\beta)^{1/5}| < 1. This implies that |a_n^5| < 1 and therefore \sum |a_n^5| converges.
(c) This is where I get confused. THis seems like an indeterminate form, we have never done this in class. same for (d) and (e). any suggestions?
Your proof of (a) doesn't make sense. In order for a series \textstyle \sum b_n to converge, it is not enough that |b_n| < 1 for sufficiently large n!
Are you thinking of the root test? If so, there is certainly an exponent missing. But the converse of the root test is false: there are convergent series \textstyle\sum b_n having |b_n|^{1/n} \to 1 as n\to\infty. So you can't conclude from the convergence of \textstyle\sum a_n^4 anything about the behavior of |a_n^4|^{1/n}. The root test is not useful here.
For (a) and (b) you should be thinking about comparisons. Bear in mind that you are not given that a_n \geq 0, so the proof that works for one of (a) and (b) will not necessarily work for the other.
For (c)-(e): The condition na_n \to 0 should make you think of a particular series whose behavior you know. Try to modify this series to construct examples that test the boundaries of the conditions here.
How does a series converge if its terms do not converge to 0?
so does my answer work? or no?
I think you might be mistaken here. Did you mean that there are sequences that where a_n \rightarrow 0 but \sum a_n doesn't converge? such as \sum \frac{1}{n}
No, I meant precisely what I said: there are convergent series whose convergence is not detected by the root test, so the converse of the root test is false. \sum\frac1{n^2} is one; it converges by comparison to the telescoping series \sum\frac1{n(n+1)}, but |n^{-2}|^{1/n} \to 1 as n\to\infty.
No. As I said, your argument for (a) establishes only that |a_n^5| < 1 for all sufficiently large n, which is very far from sufficient for convergence.
