Limiting Reagent: How Do I Determine It?
  • Thread starter Thread starter Cromptu
To determine the limiting reagent in the reaction between zinc and hydrochloric acid, one must calculate the amount of zinc chloride produced from each reactant. The calculations show that 1g of zinc produces 2.08g of zinc chloride, while 1g of hydrochloric acid produces 1.86g. Therefore, hydrochloric acid is identified as the limiting reagent since it yields the lesser amount of zinc chloride. It's important to note that limiting reagent calculations should be performed based on the amounts of reactants given, typically in moles, not just mass. Understanding the context of the question is crucial for accurate identification of the limiting reagent.
Cromptu
I have some doubts in determining the limiting reagent in a question
Based on my understanding, I will explain how I found out the limiting reagent in this problem. Please tell me if my explanation is correct or not.
Equation : Zn + 2HCl - ZnCl2 + H2
To determine the limiting reagent, we need to see how much ZnCl2 will Zn and HCl produce separately.
So,
65.4g of Zn gives 136.4g of ZnCl2
Thus 1g of Zn will give 2.08g of ZnCl2
Now,
73g of HCl gives 136.4g ZnCl2
Thus 1g of HCl will give 1.86g of ZnCl2
Now the limiting reagent is the one which produces the least amount of ZnCl2
Thus in this equation, HCl is the limiting reagent.
please tell me if my explanation is correct or not.
Please help!
Chemistry news on Phys.org
It has been a long time since I've done a question like this, but are limiting reagent questions to be done in terms of mass or in terms of moles? If they are in terms of moles then you have a problem because you'll need to know how many moles of 2HCl you need.
First of all - limiting reagent exists only if amounts of reactants are given. So if the question is "if you react 1g of Zn with 1g of HCl, which one is a limiting reagent" - you can calculate an answer. But if the question is "which is the limiting reagent if you mix Zn with HCl" - it doesn't make sense.
In other words - limiting reagent is not a "property" of the reaction.
Borek beat me to it so I leave it in his good hands.
As often here we are given an answer and have to work out what is the question; we are not too bad at it. :biggrin:
Thankyou so much :)
You guys rock! :D
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
34K
