Limiting Reagents With 3 Reactants
  • Thread starter Thread starter xChee
2 replies · 9K views
xChee
So my test is tomorrrow, and I have troubles with limiting reagents, I can get them right sometimes with the 2 reactant questions, but not always with 3... so the question is
Q: What mass of phosphorus (P4) is produced when 41.5g of calcium phosphate, 26.5g of silicon diioxide, and 7.80g of carbon are reacted according to the eqation:
2Ca3(PO4)2 + 6SiO2 + 10C -> P4 + 6CaSiO3 + 10CO
n=m/M
I've checked that the equation is balanced
and I calculated the moles of 2Ca3(PO4)2 which is 0.1337 mols, 0.441 mols for 6SiO2 and 0.0649 mols for 10C.
after this idk what ratios to use to calculate what...
No matter how many reactants, the correct answer is always the one giving the lowest amount of products.
n=m/M
Ok. First, convert all the grams given into moles.
Then, write the ratio of theoretical moles to actual moles for each compound. Finally, for each ratio, divide the whole ratio by its denominator so all the ratios have a denominator of 1. Then see which is the lowest.
Assuming you have all the grams to moles converted properly, you get this:
0.06685/1 Ca3(PO4)2
0.0735/1 SiO2
0.00649/1 C
Since 0.00649 is the least for 1 mol, then Carbon is the limiting reagent.
