MHB Proving Limits of Exponential Series at Infinity
The discussion focuses on proving the limits of exponential series as \( x \) approaches infinity. The first limit, \( \lim_{x\rightarrow \infty}\frac{e^x}{x^{\alpha}}=\infty \), is established using the exponential series expansion, demonstrating that terms with \( n > \alpha \) dominate and lead to infinity. The second limit, \( \lim_{x\rightarrow \infty}x^{\alpha}e^{-x}=0 \), is confirmed by recognizing that it is the reciprocal of the first limit, which approaches infinity. The participants clarify the treatment of non-integer values of \( \alpha \) and emphasize the positivity of terms in the series.
  • Understanding of limits in calculus
  • Familiarity with exponential functions and series
  • Knowledge of factorials and their properties
  • Basic concepts of convergence in series
  • Study the properties of the exponential function and its series expansion
  • Learn about the behavior of limits involving factorials and polynomials
  • Explore the concept of series convergence and divergence
  • Investigate the implications of non-integer factorials and the Gamma function
Mathematicians, students studying calculus, and anyone interested in advanced limit proofs and series analysis.
mathmari
MHB
Hey! :o
I want to show that $\displaystyle{\lim_{x\rightarrow \infty}\frac{e^x}{x^{\alpha}}=\infty}$ and $\displaystyle{\lim_{x\rightarrow \infty}x^{\alpha}e^{-x}=0}$ using the exponential series (for a fixed $\alpha\in \mathbb{R}$).
I have done the following:
  • $$\lim_{x\rightarrow \infty}\frac{e^x}{x^{\alpha}}=\lim_{x\rightarrow \infty}\frac{1}{x^{\alpha}}\cdot e^x = \lim_{x\rightarrow \infty}\frac{1}{x^{\alpha}}\cdot \sum_{n=0}^{\infty}\frac{x^n}{n!} = \lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{x^n}{x^{\alpha}\cdot n!}= \lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{x^{n-\alpha}}{ n!}$$
    If there are some $n$'s such that $n < \alpha$ then we separate out the finite part of the sum:
    $$\lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{x^{n-\alpha}}{ n!}=\lim_{x\rightarrow \infty} \left (\sum_{n=0}^{\alpha-1}\frac{x^{n-\alpha}}{ n!}+\frac{x^{\alpha-\alpha}}{ \alpha!}+\sum_{n=\alpha}^{\infty}\frac{x^{n-\alpha}}{ n!}\right )=\lim_{x\rightarrow \infty} \left (\sum_{n=0}^{\alpha-1}\frac{x^{n-\alpha}}{ n!}+\frac{1}{ \alpha!}+\sum_{n=\alpha}^{\infty}\frac{x^{n-\alpha}}{ n!}\right )$$
    At the first sum the exponent is negative, and so if $x\rightarrow \infty$ then $x^{n-\alpha}\rightarrow 0$.
    At the second sum the exponent is positive, and so if $x\rightarrow \infty$ then $x^{n-\alpha}\rightarrow \infty$.
    Therefore the whole limit goes to $\infty$.
    Is everything correct? Could we improve something or make it more formally? (Wondering)
  • $$\lim_{x\rightarrow \infty}x^{\alpha}e^{-x}= \lim_{x\rightarrow \infty}x^{\alpha}\cdot \sum_{n=0}^{\infty}\frac{(-x)^n}{n!} = \lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{x^{\alpha}\cdot (-1)^n\cdot x^n}{ n!}= \lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{(-1)^nx^{n+\alpha}}{ n!}$$
    Is everything correct so far? How could we continue? (Wondering)
Hi mathmari,
You say that $\alpha\in\mathbb{R}$, but, if $\alpha$ is not an integer, $\alpha!$ is not defined. That is easy to cope with: you can replace $\alpha$ with any integer $k>\alpha$; this will make the expression smaller, and, if it still tends to infinity, you are fine.
If $\alpha\le0$, there is no problem, since the finite part of the sum will disappear.
For the second term, although the general term tends to 0 for any fixed $x$, any particular term tends to infinity, and, as all terms are positive, the sum tends to infinity; this is probably what you mean, but it does no harm to state it explicitly.
For the second part, you could simply observe that the second expression is the inverse of the first one, and use the result of the first part.
Do you mean it as follows?
If $\alpha>0$ we let $k$ be the smallest interger such that $k\geq a$, then we have the following:
$$\lim_{x\rightarrow \infty} \sum_{n=0}^{\infty}\frac{x^{n-\alpha}}{ n!}=\lim_{x\rightarrow \infty} \left (\sum_{n=0}^{k}\frac{x^{n-\alpha}}{ n!}+\sum_{n=k+1}^{\infty}\frac{x^{n-\alpha}}{ n!}\right )$$
Or do we split the sum at $k-1$ instead of $k$ ? (Wondering)
What exactly do you mean by "the general term tends to 0 for any fixed $x$" ? (Wondering)
Hi mathmari,
What I mean is that, if $k>\alpha$, we have:
$$\displaystyle 0 < \frac{e^x}{x^k} < \frac{e^x}{x^\alpha}$$
for $x>1$ (we may assume that $x>1$, since we are interested in what happens for $x\to\infty$).
Therefore, if you can prove that $\dfrac{e^x}{x^k}\to\infty$, the conclusion will follow.
The means that you can completely forget $\alpha$, and prove the proposition for $\dfrac{e^x}{x^k}$; as you can choose $k$ subject ot the condition $k>\alpha$, you may assume that $k$ is an integer, which avoids the problem with the factorials. In practice, this is equivalent to assuming that $\alpha$ is an integer. In particular, you may write $n-k$ instead of $n-\alpha$ for the exponents.
It does not really matter where you split the sum. What is important is that all the terms of the sum are positive, and it is enough to prove that at least one term tends to infinity. This is the case, for example, for the term $\dfrac{x}{(k+1)!}$.
We can consider the sum as a series in $n$ for $x$ fixed, or as a function of $x$. I just wanted to point out that, for $x$ fixed, $\dfrac{x^{n-k}}{k!}\to0$ as $n\to\infty$ (in fact, we know that the series converges because we know its limit). This is not what we are interested in, however, and I only wanted to avoid any confusion.
Hi mathmari,
After thinking a bit more about this, I realize that we may be making it much harder than it needs to be.
We have:
$$\displaystyle
\frac{e^x}{x^\alpha} = \sum_{n=0}^\infty \frac{x^{n-\alpha}}{n!}
The important facts about this series are:
  • Like the exponential series, it converges for all $x$.
  • If $x>0$ (in particular, if $x\to\infty$), all the terms are positive.
Now, the series contains at least one (actually, infinitely many) term with $n>\alpha$, and this term tends to $+\infty$. As the other terms are positive, they can only make the function grow faster, and we conclude that the function tends to infinity. You don't need to split the series or worry about non-integral or negative values of $\alpha$.
Happy Christmas!
castor28 said:
We have:
$$\displaystyle
By "As the other terms are positive, they can only make the function grow faster", do you mean as "other terms" the ones with positive exponent, i.e. the ones with $n>\alpha$, or all the other terms including the ones with negative exponent? (Wondering)
About the other limit, can we say something similar, or can we just say the following:
We have:
$$\displaystyle
x^{\alpha}e^{-x}=\frac{x^{\alpha}}{e^x}=\frac{1}{\frac{e^x}{x^\alpha}}
Since $\frac{e^x}{x^\alpha}$ goes to infinity as $x$ goes to infinity, it follows that $\frac{1}{\frac{e^x}{x^\alpha}}$ and so $x^{\alpha}e^{-x}$ goes to $0$.
castor28 said:
Happy Christmas!
I wish you also a Merry Christmas! (Smile)
Hi mathmari,
I mean all the other terms. More precisely, if $k$ is any integer greater than $\alpha$, the sum contains a term $\dfrac{x^{k-\alpha}}{k!}$, which tends to $+\infty$ because the exponent is positive.
As all the terms are positive, we have:
$$\displaystyle
\sum_{n=0}^\infty \frac{x^{n-\alpha}}{n!} > \frac{x^{k-\alpha}}{k!} \to+\infty
and this shows that the sum tends to $+\infty$.
We have:
$$\displaystyle
That is perfectly correct: if $f(x)\to\infty$, then $\dfrac{1}{f(x)}\to0$.
$$\displaystyle
I see! Thank you so much! (Smile)
  • · Replies 23 ·
  • · Replies 38 ·
