Finding Inclination of Line: x = [a number]
  • Context: High School
  • Thread starter Thread starter Chen
    Line
The discussion centers on finding the inclination (slope) of a line represented by the equation y = mx + n, where m denotes the slope. The user attempts to solve the equation 2m + 1 = 2m + 4, concluding that no value of m satisfies it, indicating that the line is vertical, expressed as x = [a number]. The problem involves a triangle ABC with line BC defined by 3x - 4y + 37 = 0 and angle bisectors BE and CF. The user successfully determines that line AB is vertical, with coordinates B at (5, 13) and the equation of AB as x = 5.
  • Understanding of linear equations in slope-intercept form (y = mx + n)
  • Knowledge of angle bisectors in geometry
  • Familiarity with solving linear equations
  • Concept of perpendicular lines in coordinate geometry
  • Study the properties of angle bisectors in triangles
  • Learn how to derive the equations of lines from given points
  • Explore the concept of vertical lines and their equations
  • Investigate the relationship between slopes of perpendicular lines
Students studying geometry, particularly those focusing on line equations and triangle properties, as well as educators looking for practical examples of slope and angle bisectors.
Chen
(I don't study math in English so I'm not sure what the exact terms are... please bear with me. :))
If you have this line:
y = mx + n
m is the inclination of the line, right? And I have this equation to find m:
2m + 1 = 2m + 4 (I'm finding a line between two other lines that divides the angle in half)
Obviously no m can solve that equation - this means that the line is reall of the form:
x = [a number]
Am I correct?
Mathematics news on Phys.org
Knowing only what you've written here, my best guess is that you're correct. What was the entire problem?
P.S. we would call m the slope of the line.
The whole problem was this:
You have a triangle ABC, with BC on the line:
3x - 4y + 37 = 0 (BC)
And then you also have the equations for the two lines that divide the angles B and C of the triangle:
2x - y + 3 = 0 (BE)
x + 7y - 4 = 0 (CF)
I solved it by finding the slope of both AB and AC, and then finding B and C, and then finding the equations of AB and AC, and finally finding the coordinates of A.
To find m (slope of AB) I did this: (based on the given that the angle between AB and BE is the same as the angle between BE and BC)
(2 - m) / (1 + 2m) = (3/4 - 2) / (1 + 6/4) = -1/2
-4 + 2m = 1 + 2m
-4 = 1
And from this I deduced that the line AB is perpendicular (sp?) to the X axis. I found B to be (5, 13) and since it is on the AB line I figured that AB was x = 5.
Thanks for the help. :-)
  • · Replies 16 ·
