Finding Points of Intersection and Proving Parallelism with Vectors
  • Context: Undergrad
  • Thread starter Thread starter StonedPanda
    Line Plane
This discussion focuses on finding the intersection of the line defined by the parametric equations x = 3 + 2t, y = 7 + 8t, z = -2 + t with the coordinate plane, specifically the XY plane. The intersection point is determined by setting z = 0, which yields the intersection at (9, 23, 0) when t = 2. Additionally, the discussion covers proving that the line segment joining the midpoints of two sides of a triangle is parallel to and half the length of the third side using vector addition, establishing the relationship through the equation (1/2)(a + b) = (1/2)c.
  • Understanding of parametric equations in three-dimensional space
  • Knowledge of vector addition and properties of vectors
  • Familiarity with coordinate planes, specifically the XY plane
  • Basic concepts of triangle geometry and midpoints
  • Study vector operations and their applications in geometry
  • Learn about parametric equations and their intersections with planes
  • Explore the properties of triangles and midpoints in Euclidean space
  • Investigate the concept of vector parallelism and its proofs
Students and educators in mathematics, particularly those focused on geometry and vector calculus, as well as anyone seeking to enhance their understanding of spatial relationships and vector proofs.
StonedPanda
How would I find the points of intersection of the line x= 3+2t , y= 7+8t , z=-2+t , that is, l(t) = (3+2t,7+8t,-2+t) with the coordinate plane?
Also, how would I prove using vectors that the line segment joining the mdpoints of two sides of a triangle is parallel to and has half the length of the third side? I'm going to try this one some more before I look for the answers, but please give me some guidance for both of them!
Figured it out!
If z=0, then you have the XY plane. So, find what T value makes z zero (2 in this case).
Then, plug in 2 for t in x and y (you get 9 and 23 respectively). Thus, the point it intersects the XY plane is (9,23,0).
That feels good!
Make it so that a points upwards and right, make b point down and right, and make c = a + b. You know the line segment joining the midpoints is:
(1/2)a + (1/2)b
= (1/2)(a + b)
= (1/2)(c)... Q.E.D.
For the first one, I'm not sure what you're referring to by "the co-ordinate plane," but you seem to have gotten that one, so you're fine.
Scuse me akg! It should have been Coordinate Planes =p mb
But, wouldn't c = a - b if a points upright and b points downright?
Not if you define c as a + b!
cookiemonster
Nope, it would be as I wrote it. Think about it: start at the "starting point" of a, and go in the direction that it goes in. Now, since you're adding b, you then proceed in the direction that b goes in, which is down. In this process you will have started at the "start" of c and ended at the "end."
Ok, I get it. If a points downleft and b points downright, then c is b-a . Is this correct sir?
Btw, thanks for your help akg and cook!
Yes, that's correct.
Vectors are incredibly powerful. I've taken 4 classes of multivarient calc so far, and my knowledge of math increased exponentially!
