Linear Algebra Conditions: Solving for ab≠1
The discussion revolves around the conditions under which a system of linear equations has a unique solution, specifically focusing on the condition that ab≠1. The context includes mathematical reasoning related to linear algebra and solving equations.
  • Some participants propose that the condition for a unique solution in a system of linear equations is that the determinant of the coefficient matrix must be non-zero, specifically noting that it equals 2 - 2ab.
  • One participant explains the steps taken to solve the equations and highlights that division by zero occurs when ab=1, which prevents finding a unique solution.
  • Another participant expresses gratitude for the detailed response received, indicating that they found it more helpful than previous attempts at seeking help.
Participants generally agree on the condition that ab must not equal 1 for the system to have a unique solution, but the discussion does not explore any competing views or unresolved issues.
The discussion assumes familiarity with determinants and the process of solving linear equations, but does not address potential limitations or alternative methods for solving the system.
Terry_Destefano
The answers is b) ab≠1, but I have no clue how to get to that answer... Can someone help me? :D
One answer to this is that, in order that a system of linear equations have a unique solution is that the determinant of coefficient, here $$\left|\begin{array}{cc}1 & b \\ 2a & 2 \end{array}\right|= 2- 2ab$$ be non-zero. (This is the answer you got to your post of this question on another board.)
More fundamentally, what happens if you try to solve the equations? To solve x+ by= -1, 2ax+ 2y= 5, we might start by multiplying the first equation by 2, 2x+ 2by= -2. Multiply the second equation by b, 2abx+ 2by= 5b. Now, since both equations have "2by", subtracting one equation from the other (2- 2ab)x= -2- 5b. Finally, divide the both sides by 2- 2ab: x= (-2- 5b)/(2- 2ab). Given that value for x, we could put it into either of the two original equations to solve for y.
Under what conditions can we not do that? Every step above is easy to do for all values of a and b except "divide both sides by 2- 2ab". We cannot do that if 2- 2ab= 0 because we cannot divide by 0. There is a unique solution for all a or b except a and b so that 2- 2ab= 2(1- ab)= 0. That is the same as ab= 1. The given system of equations has a unique solution if and only if ab is not equal to 1.
Thanks HallsofIvy!
I put my question at many forums and even payed for homework help but you gave me the most detailed response.
Thanks HallsofIvy!
There's no need to link to the commercial site you used. Thanks! :D
  • · Replies 19 ·
  • · Replies 44 ·
