MHB Linear Algebra Conditions: Solving for ab≠1
The discussion centers on determining the condition for a system of linear equations to have a unique solution, specifically when ab≠1. The key point is that the determinant of the coefficient matrix must be non-zero, leading to the conclusion that 2 - 2ab must not equal zero. If ab equals 1, the equations become unsolvable due to division by zero. The unique solution exists for all values of a and b except when ab equals 1. The response provided was appreciated for its clarity and detail.
Terry_Destefano
The answers is b) ab≠1, but I have no clue how to get to that answer... Can someone help me? :D
One answer to this is that, in order that a system of linear equations have a unique solution is that the determinant of coefficient, here $$\left|\begin{array}{cc}1 & b \\ 2a & 2 \end{array}\right|= 2- 2ab$$ be non-zero. (This is the answer you got to your post of this question on another board.)
More fundamentally, what happens if you try to solve the equations? To solve x+ by= -1, 2ax+ 2y= 5, we might start by multiplying the first equation by 2, 2x+ 2by= -2. Multiply the second equation by b, 2abx+ 2by= 5b. Now, since both equations have "2by", subtracting one equation from the other (2- 2ab)x= -2- 5b. Finally, divide the both sides by 2- 2ab: x= (-2- 5b)/(2- 2ab). Given that value for x, we could put it into either of the two original equations to solve for y.
Under what conditions can we not do that? Every step above is easy to do for all values of a and b except "divide both sides by 2- 2ab". We cannot do that if 2- 2ab= 0 because we cannot divide by 0. There is a unique solution for all a or b except a and b so that 2- 2ab= 2(1- ab)= 0. That is the same as ab= 1. The given system of equations has a unique solution if and only if ab is not equal to 1.
Thanks HallsofIvy!
I put my question at many forums and even payed for homework help but you gave me the most detailed response.
Thanks HallsofIvy!
There's no need to link to the commercial site you used. Thanks! :D
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 19 ·
  • · Replies 19 ·
