Linear Algebra: Is the matrix diagonalizable?
3 replies · 5K views · last reply
Theorem.
Let A be a square matrix and [tex]f_A (\lambda)[/tex] its characteristic polynomial. In each of the following cases (i) to (iv), write down whether
A is diagonalizable over R
A is not diagonalizable over R
its not possible to say one way or the other.
THEN say whether or not the matrix can certainly be diagonalizable over C
I am only having trouble with the following case:
[tex]f_A (\lambda)=(\lambda^2+3)^2[/tex]
There aren't any relevant equations strictly speaking
Well it is clear that the eigenvalues are [tex]\sqrt{3}i and -\sqrt{3}i[/tex], both having multiplicity 2 in the characteristic polynomial. Clearly then A is not diagonalizable over R as its eigenvalues are not real. Where I get stuck is deciding if the matrix can certainly be diagonalizable over C or not. from the characteristic polynomial I see that A is 4x4, and it does not have 4 distinct eigenvalues, which doesn't help me. I am not sure how to approach this really its the first time I have encoutered a characteristic polynomial of this sort and can't seem to find anything helpful in my textbook. Any help/advice would be greatly appreciated
-Curtis
if an nxn matrix has n distinct eignvalues in a field Q, then it is diagonalisable over Q.
if the eignevalues are not in Q, it is not diagonalisable over Q
if there are repeated eigenvalues, then you can't say until you check the dimensions of the eigenspaces sum to n
Thanks for the reply lanedance,
This is the criteria I used when I evaluated the 3 other cases (which I did not post here). I think when I read the question I thought that for the complex portion of the question, I was to state whether the Matrix was diagonalizable or not (Yes/No as apposed to Yes/No/Can't tell), Perhaps I have just read the question wrong?
This matrix definitely falls in the last category: All its Eigenvalues are in C, but it is impossible to say whether or not the dimensions of the eigenspaces sum to n without being given the matrix itself (as there are repeated eigenvalues).
