Linear Algebra - REF with another variable
Schaus
Determine the values of a for which the following system of linear equations has no solutions, a unique solution, or infinitely many solutions. You can select 'always', 'never', 'a = ', or 'a ≠', then specify a value or comma-separated list of values.
x1−2x2+2x3 = −1
−3x1+ax2−10x3 = 5
x1+x2−4x3 = 3
Augmented Matrix
-3 a -10 5
1 1 -4 3
I switched the row with the variable to the bottom.
1 -2 2 -1
1 1 -4 3
-3 a -10 5
I minused Row 1 from Row 2
1 -2 2 -1
0 3 -6 5
-3 a -10 5
3Row 1 + Row 3
1 -2 2 -1
0 3 -6 5
0 (a-6) -4 2
Here is where I get confused. I don't know how to get the 3 in row 2 to equal 1 and get the (a-6) to equal 0.
Any advice as to where I went wrong or what I need to do next would be greatly appreciated!
on Phys.org
Let's begin with the augmented matrix:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\ -3 & a & -10 & 5 \\ 1 & 1 & -4 & 3 \end{array}\right]##
You switched the 2nd and 3rd rows:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\1 & 1 & -4 & 3 \\ -3 & a & -10 & 5\end{array}\right]##
Next, you performed ##R_2-R_1##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 3 & -6 & 4 \\ -3 & a & -10 & 5\end{array}\right]##
Note: I have corrected an arithmetic error. Next, you performed ##3R_1+R_3##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 3 & -6 & 4 \\ 0 & a-6 & -4 & 2\end{array}\right]##
What can we multiply the second row by to get the 3 to be a 1?
Divide that row by 3.
Use the determinant! When ##\text{det}[\mathbf{A}]=0## there will be no unique solution.
Let's take FactChecker's advice and perform ##\dfrac{1}{3}R_2##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 1 & -2 & \frac{4}{3} \\ 0 & a-6 & -4 & 2\end{array}\right]##
Now, obviously, we need to perform ##2R_2+R_1##:
##\left[\begin{array}{ccc|c}1 & 0 & -2 & \frac{5}{3} \\0 & 1 & -2 & \frac{4}{3} \\ 0 & a-6 & -4 & 2\end{array}\right]##
Now, we need to perform ##x\cdot R_2+R_3## such that:
##x\cdot1+(a-6)=0##
What is ##x##, and what do you get after performing the operation?
So I take (a+6)R2-R3?
1 0 -2 ----------- 5/3
0 1 -2 ------------ 4/3
0 0 (-2a-16) -------- ((4/3)a+10)
Sorry for the slow reply, I've been very busy with school.
No, that won't work. In column 2, (a + 6) * 1 - (a - 6) ##\neq## 0.
So I should have multiplied by -(a-6)?
-(a-6)R2+R3
0 0 (2a-16) -------- ((4/3)a-6)
-(a-6)R2+R3
Yes, assuming that your work leading up to this last matrix is correct (I didn't check).
Now, for what value(s) of a will there be a unique solution, no solution, or an infinite number of solutions?
2a-16 = ((4/3)a-6)
a=15
No solution = Never
Unique solution ---- a≠15
Infinitely many solutions--- a=15?
Schaus said:
2a-16 = ((4/3)a-6)
a=15
No solution = Never
No. Where did 15 come from?
A bit more of a hint. Suppose that each of the following was the bottom row of your augmented matrix:
1) 0 0 0 | 5
2) 0 0 0 | 0
3) 0 0 1 | 2
and that the 2nd and 3rd rows had leading entries of 1.
For which of the above 3rd rows would we expect a) a unique solution, b) no solution, c) an infinite number of solutions?
1) No solution
2) Infinitely many solutions
3) One unique solution
I got the a=15 by making 2a-16 = (4/3a-6)
Schaus said:
1) No solution
Yes to all of the above.
That seems like a reasonable thing to do, but it's not. You're not solving the equation 2a - 16 = (4/3)a - 6. Instead, you're trying to make the coefficient of z (what I'm calling the 3rd variable) equal to 1.
In other words, the bottom row of your matrix corresponds to the equation (2a - 16)z = (4/3)a - 6. What do you need to do to turn this into 1z = <something>? In particular, are there any values of a that will cause problems?
