Linear approximation of Non linear system by Taylor series
The discussion focuses on the linearization of a nonlinear system using the tangent line approximation rather than the Taylor series. The specific function analyzed is y = 5.68x / (1 + 4.68x), and the derivative is calculated using the quotient rule, resulting in dy/dx = 5.68 / (1 + 4.68x)^2. The linear approximation is expressed as y = (5.68 / (1 + 4.68x̄)^2)(x - x̄) + (5.68x̄ / (1 + 4.68x̄)). The user seeks clarification on the transition from equation 5.5b to 5.6, noting discrepancies in their application of the linearization method.
  • Understanding of nonlinear systems and their properties
  • Familiarity with differentiation techniques, specifically the quotient rule
  • Knowledge of linear approximation methods
  • Basic algebraic manipulation skills
  • Study the application of linear approximation in nonlinear systems
  • Learn more about the quotient rule in calculus
  • Explore the differences between Taylor series and linear approximation
  • Investigate common pitfalls in deriving linearized equations from nonlinear forms
Students and professionals in mathematics, engineering, and physics who are working with nonlinear systems and require a solid understanding of linearization techniques.
mac1
I have a equation which represents a nonlinear system.I need to linearize it to obtain a linear system.I have studied various notes and asked my teachers but they are unable to explain how the solution has been obtained.I have the solution but I want to know how it has been done.Please could someone explain it to me.
Image file eqn1- The highlighted text shows the simple way of linearisation using Taylor series.
Image file eqn2- The FIRST highlighted equation shows the equation to be linearized and the SECOND highlighted equation is the linearized form.
So,please help me to find the method by which eqn 5.6 has been obtained from eqn 5.5b.
Thanks.
First point: to get a linear approximation, you don't really need to know about "Taylor series". You just need to know that tangent line to y= f(x), at [tex]\left(\overline{x}, f(\overline{x})\right)[/tex] is given by [tex]y= f'(\overline{x})(x- \overline{x})+ f(\overline{x})[/tex].
In this particular case, [tex]y= f(x)= \frac{5.68x}{1+ 4.68x}[/tex], we can use the "quotient rule" to differentiate:
[tex]\frac{dy}{dx}= \frac{5.68(1+ 4.68x)- 5.68x(4.68)}{(1+ 4.68x)^2}[/tex]
The two "5.68(4.68x)" terms in the numerator cancel leaving
[tex]\frac{dy}{dx}= \frac{5.68}{(1+ 4.68x)^2}[/tex]
So the linear approximation to the function, at [tex]\overline{x}[/tex] is
[tex]y= \frac{5.68}{(1+ 4.68\overline{x})^2}(x- \overline{x})+ \frac{5.68\overline{x}}{1+ 4.68\overline{x}}[/tex]
Thanks for the reply sir.I have understood how linearisation was done for the first equation 5.1.
But I want to know how eqn 5.6 was obtained from eqn 5.5b.I used the same concept and applied it to 5.5b but I am getting two terms more than the eqn 5.6 : 1/Mn(yn-1*Vn - ynVn). consider yn as yn bar.
