Linear combination of linear combinations?
The discussion centers on the notation [[S]] and its relationship to [S], where [S] represents the span of a subset S in a finite-dimensional vector space V. It clarifies that [[S]] is essentially a linear combination of linear combinations of elements from [S], and confirms that [[S]] equals [S]. The conversation also touches on the equivalence of different definitions of a set E in relation to subsets of V, emphasizing that the [[]] notation is not fundamentally different from the [] notation. Participants suggest using clearer mathematical notation for better understanding. Ultimately, the key point is that [[S]] is defined through repeated application of the linear combination concept.
bonfire09
When the book says "Members of [] are linear combinations of linear combinations of members of S". basically means the span of the members in subspace S. Since
= {c1s1 +... + cnsn|c1...cnεR and s1...snεS} what does [] mean? does it mean a linear combination of atleast one linear or more linear combinations from ?
Let V be a finite-dimensional vector space. For all subsets S⊂V, is the set of all v in V such that v is equal to a linear combination of members of S. Since that makes a subset of V, the definition applies to as well. So [] is the set of all v in V such that v is equal to a linear combination of members of .
It's possible to prove that if E,F⊂V, the following statements are equivalent (i.e. they're either all true or all false).
(a) E is the set of all v in V such that v is a linear combination of members of F.
(b) E is the intersection of all subspaces that have F as a subset.
(c) E is the smallest subspace that has F as a subset. (This means that if E' is a subspace that has F as a subset, E⊂E').
A set E for which these statements are true is, in your notation, denoted by [F]. If you only look at (a), it's not obvious that []=, but if you look at the other two statements, it is.
Two alternative notations for : span S, ##\bigvee S##.
Yeah I forgot to mention []=. But the book states that [] is a linear combination of linear combinations of the members of . Does this let's say set R={c1,1s1+...+cn,1sn,...,c1,m s1+...+cn,m sn} which is the set of all linear combinations of . And [] just means taking a linear combination of those members in R such as
r1(c1,1s1+...+cnsn)+...+rn(c1,m s1+...+c n,m sn) ? Oh s1,...sn. are elements of S and S is a subspace of V
I thought that was what you were asking about, not something you already knew.
You mean "of S", right? (Not "of ").
What does that mean? And did you again mean S when you wrote ?
I don't understand what you're asking, but the meaning of [] is given by the definition of the [] notation.
Maybe you meant to ask this: If we define R=, does that make []=[R]? The answer is of course yes. The [[]] notation isn't something entirely different from the [] notation. It's just the [] operation done twice.
It doesn't have to be.
I recommend that you start using LaTeX, or at least vBulletin's sup and sub tags. (Like this: E=mc2).
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 23 ·
