Converting Non-Linear DE: From Standard Form to Integrating Factor
  • Thread starter Thread starter basty
    Linear
The equation presented is a non-linear differential equation due to the term involving \( y^6 \), which prevents it from being expressed in the standard linear form. The discussion highlights the need to recognize that the equation is not linear and questions the appropriateness of seeking an integrating factor. Instead, it suggests examining conditions for the equation to be exact, referencing the relationship between the functions \( P \) and \( Q \). If the equation is not exact, the possibility of finding an integrating factor to make it exact is also raised. Understanding these concepts is crucial for solving non-linear differential equations effectively.
basty
This problem appears as one of exercise, of a linear differential equations chapter in my DE book.
##y \ dx - 4(x + y^6) \ dy = 0##
How to change above equation in a standard form of a linear differential equation?
The standard form of a linear differential equation is:
##\frac{dy}{dx} + P(x) y = f(x)##
It appears that the above equation is not linear because the power of ##y## is not 1 instead of 6.
Also, what is its integrating factor ##(e^{\int P(x) \ dx})##?
##y - 4(x + y^6) \frac{dy}{dx} = 0##
##4(x + y^6) \frac{dy}{dx} - y = 0##
##\frac{dy}{dx} - \frac{1}{4(x + y^6) }y = 0##
You are correct. It is not linear.
That's the wrong question to ask. Your equation is in the form ##Pdx + Qdy=f(x)##. Look in your text about exact DE's and what condition on ##P## and ##Q## makes the equation exact.
[Edit, added] And if the equation isn't exact is it possible to find an integrating factor that makes it exact?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
