Linear Dependence of Matrix Vectors
zplot
I need to prove that the set {I, A, A^2,..., A^n} is linear dependent where A is any nxn matrix. The vector space is the set of nxn matrix, considered as a nxn dimensional vector space.
Does anybody have an idea how to prove it?
Thank you very much.
well I maybe wrong but to get you started:
I is in the nxn vector space and all the other matrices A, A^2, ..A^n
You might start by showing the linear combinations of matrices to get I and then relate that to the matrices A, of which matrices' can be written as nxn A^n=PA(^n)P^(-1)
Well, I tried to write A=P^(-1) J P where J is a Jordan matrix. Even more, I also tried to put J=N + D where N is nilpotent such that N^n=0 and D diagonal but I could not prove that the set is linear dependent. Thank you for your help. I f you have any further details or ideas I would be pleased.
At the end I arrived at the right solution. (A-lambda I)^k must be zero for some k<n. It comes from the Jordan canonical matrix, where lambda belongs to its spectrum. Logically then, the set {I, A, A^2,..., A^n} is linear dependent.
Thank you
An alternative method, which gives you the exact dependence right off the bat, is to use the Cayley-Hamilton theorem. The characteristic polynomial is of degree at most n, and is satisfied by the matrix.
Great! Thats certainly a much better, simpler and more elegant solution.
Thank you very much, Henry.
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
