Linear first-order ODE with initial condition y(0)=8
  • Thread starter Thread starter Omega_Prime
    Ode Stuck
8 replies · 3K views
Omega_Prime
Solve the initial value problem:
y'+[itex]\frac{4y}{x+8}[/itex]=(x+8)[itex]^{8}[/itex] , y(0)=8.
The differential equation is linear.
N/A
I can see that the equation is in the form y' +P(x)*y = Q(x) so I'm like "easy, let me get an integration factor going and solve this mofo."
I= e[itex]^{\int P(x)dx}[/itex] = e[itex]^{\int \frac{4}{x+8}dx}[/itex] = e[itex]^{4 ln |x+8|}[/itex] = (x+8)[itex]^{4}[/itex] (I took the positive expression since any number raised to the 4th power is positive...)
Then multiply the equation by I:
(x+8)[itex]^{4}[/itex]*y' + (x+8)[itex]^{4}[/itex]*4(x+8)[itex]^{-1}[/itex]*y = (x+8)[itex]^{4}[/itex]*(x+8)[itex]^{8}[/itex]
Simplify
y'(x+8)[itex]^{4}[/itex]+4y(x+8)[itex]^{3}[/itex] = (x+8)[itex]^{12}[/itex]
Now the LHS is the derivative w/ respect to x for the product y*(x+8)[itex]^{4}[/itex] and by integrating both sides I get:
y(x+8)[itex]^{4}[/itex] = [itex]\frac{(x+8)^{13}}{13}[/itex] + C
So now I solve for C given the initial conditions and I get a big *** negative number
C = [itex]\frac{104-8^{9}}{13}[/itex] = -[itex]\frac{134217624}{13}[/itex]
My final solution looks like this (gotten it 3 times now, so I must be doing the same mistake over and over...)
y = [itex]\frac{(x+8)^{9} - 134217624}{13}[/itex]
I feel an almost instinctual compulsion to reject any answer that is ginormous or just crazy looking when it comes to homework problems.. but I submitted anyway and sure enough I'm incorrect. Anyone got a bone to throw for me?
Solve for y here. Don't plug in the initial condition right away.
I didn't think it'd matter... I get the same thing.
y = [itex]\frac{(x+8)^{9}}{13}[/itex] + C[itex]_{1}[/itex] | where C[itex]_{1}[/itex] is just another arbitrary constant that will satisfy the equation given the initial conditions. I get the same constant regardless...
8 = [itex]\frac{8^{9}}{13}[/itex] + C[itex]_{1}[/itex]
C[itex]_{1}[/itex] = 8 - [itex]\frac{8^{9}}{13}[/itex] = -[itex]\frac{134217624}{13}[/itex]
mohaque said:
You integrated too soon, write out the dy/dx.
Ok let me look at that, thanks.
No luck. Oh well, thanks for your time I guess.
That's such a ridiculous question, who came up with it?
I keep getting something different than you, a really big number. I think you're supposed to divide the C by the (x+8)^4. You can't change that to another constant because (x+8)^4 isn't a constant. I keep getting -4.22889088e10. Kinda of a ridiculous C and problem.
You're fine up to here. But for y(0) = 8 , shouldn't this be
[tex]8 \cdot 8^{4} = \frac{8^{13}}{13} + C[/tex]
[tex]\Rightarrow 8^{5} = \frac{8^{13}}{13} + C ,[/tex]
and so
[tex]C = 8^{5} - \frac{8^{13}}{13} ?[/tex]
[Note: you are not obligated to simplify this -- in some situations, it isn't even desirable to do so.]
Your solution function is then
[tex]y = \frac{(x+8)^{9}}{13} + [ 8^{5} - \frac{8^{13}}{13} ] \cdot \frac{1}{(x+8)^{4}} .[/tex]
[In your entry above, don't forget that the "arbitrary constant" also getting divided by (x+8)4.]
It is pretty easy to see, in this form, that your initial condition is satisfied.
As far as how you'd come up with such a strange differential equation and solution function, this can arise from the sort of "mixing problems" involving finding the mass function of a substance where solutions of different concentrations are being added and drained from a tank (in which they are "instantaneously mixed"), with the inflow rate being greater than the drainage rate.
Thank you so much guys, I was banging my head on my desk with that. The solution
y = [itex]\frac{(x+8)^{9}}{13}[/itex] + (8[itex]^{5}[/itex] - [itex]\frac{8^{13}}{13}[/itex])(x+8)[itex]^{-4}[/itex]
checked out.
