Linear least square method for singular matrices
9 replies · 21K views · last reply
alyflex
I have stumbled upon a problem which I have so far been unable to solve.
I we consider a general set of linear equations:
[tex]Ax=b[/tex],
I know the the system is inconsistent which makes least square method the logical choice.
So the mission is to minimize [tex]||Ax-b||[/tex]
And the usual way I do this is by setting Ax=p, where p is the projection of b onto Ax.
By isolating:
[tex]x=(A^TA)^{-1}A^T \cdot p<br /> =(A^TA)^{-1} \cdot A^T \cdot b[/tex]
However the product [tex]A^T*A[/tex] is also singular, and thus I am unable to do this.
I pretty sure there is a very simple way to do this, but when i look in my old algebra book I see no solution to the problem.
Anyone know the way?
Yes, that is the standard "least squares" method for solving such a problem with [itex](A^TA)^{-1}A^T[/itex] being the "generalized inverse". For most such problems [itex]A^TA[/itex] is invertible. If your A is such that [itex]A^TA[/itex] is not invertible then you have a very pathological problem for which there probably is no "simple" way to solve it. What is A?
Isn't it true that [tex]A^TA[/tex] is only not invertible if there are actually multiple solutions to [tex]Ax=b[/tex]?
Correct. The least square solution satisfies the normal equation A^TAx=A^Ty. This solution is unique if and only if A^TA is invertible. See here for a similar discussion.
I can think of a couple of possibilities, both involving miniminum norm solutions. If A has more columns than rows, it is an underdetermined system that has an easy 'least norm' solution. If A has more rows than columns and is rank deficient (my guess in your case), there is a way to minimize the norm of Ax-b and the norm of x at the same time using SVD, but I'm not familiar with the details. Look up LAPACK DGELSS.
* DGELSS computes the minimum norm solution to a real linear least
* squares problem:
* Minimize 2-norm(| b - A*x |).
* using the singular value decomposition (SVD) of A. A is an M-by-N
* matrix which may be rank-deficient.
This was what I suspected, but thanks for making it clear. Now I just need a method to compute it for non-invertible matrices
The more I look at this the more afraid I am, that a numerical solution might be the best way. I was really hoping for a clear and illuminating analytical method.
HallsofIvy said:
What is A?
The initial system I stumbled upon was this:
[tex]\left[ {\begin{array}{ccc}<br /> 1 & 1 & 3 \\<br /> -1 & 3 & 1 \\<br /> 1 & 2 & 4 \\<br /> \end{array} } \right]<br /> \left( {\begin{array}{c}<br /> x \\<br /> y \\<br /> z \\<br /> \end{array} } \right) <br /> = \left( {\begin{array}{c}<br /> -2 \\<br /> 0 \\<br /> 8 \\<br /> \end{array} } \right)[/tex]
but then I considered more simple system but with the same problem.
One example could be:
y=x
y=x+1
It is clear what the least square solution to this system should be, but I have no idea how to find it methodically
Consider A being column eliminated with R as
[tex] A R R^{-1}x = b[/tex]
Then,
[tex] \left[ {\begin{array}{ccc}<br /> 1 & 0 & 0 \\<br /> -1 & 4 & 0 \\<br /> 1 & 1 & 0 \\<br /> \end{array} } \right] \left( {\begin{array}{c}<br /> x + y +3z \\<br /> y +z \\<br /> z \\<br /> \end{array} } \right) =\left( {\begin{array}{c}<br /> -2 \\<br /> 0 \\<br /> 8 \\<br /> \end{array} } \right)[/tex]
now we solve a different linear eq. set, since the last variable does not play a role in the equations we reduce the number of columns.
[tex] \underbrace{\left[ {\begin{array}{cc}<br /> 1 & 0 \\<br /> -1 & 4 \\<br /> 1 & 1 \\<br /> \end{array} } \right]}_{A_r} \left( {\begin{array}{c}<br /> x + y +3z \\<br /> y +z<br /> \end{array} } \right) = \left( {\begin{array}{c}<br /> x + y +3z \\<br /> -x +3y + z \\<br /> x+2y+4z<br /> \end{array} } \right) =\underbrace{\left( {\begin{array}{c}<br /> -2 \\<br /> 0 \\<br /> 8 \\<br /> \end{array} } \right)}_{b}[/tex]
From the second equation, you can see that it is not solvable. So back your least squares, and call the variables a b i.e.
[tex] \left( {\begin{array}{c}<br /> x + y +3z \\<br /> y +z<br /> \end{array} } \right) = \begin{pmatrix}a\\b\end{pmatrix}[/tex]
And Matlab gave (from linsolve(Ar,b))
[tex] \begin{pmatrix}a\\b\end{pmatrix} = \begin{pmatrix}3\\1\end{pmatrix}[/tex]
And from this solution, you can construct admissible least squares solutions. I might have made mistakes so please check the steps but conceptually it should be OK if I didn't mess it up. To your small example, the least squares solution is a = y-x = 0.5 So the whole trick is to embed the underdetermined part inside the x vector and solve the least squares solution. Then you get infinitely many solutions that satisfy the least squares solution.EDIT: By the way, I forgot to write that any full rank decomposition of [itex]A = MN^T[/itex] leads to a similar solution. Similarly with SVD mentioned above.
Thank you very much for the illuminating answer trambolin.
I'm going to work it through in the weekend using your method.
I'll post a longer and more conclusive reply once I have tried the method.
But to all of you, thank you very much for an enlightening discussion on a subject, which was causing me severe headaches yesterday. =)
Well I just went through the calculation myself and as far as I can see everything you wrote was spot on, so thank you very much.
Btw I had no idea that the linsolve function in MATLAB solved a system of linear equations using least squares, I only thought it could find consistent solutions.
alyflex,
Try the truncated SVD of the matrix A (Demmel, Applied Numerical Linear Algebra). Let [tex]A=U\Sigma V^T[/tex] where [tex]A,U\in \Re^{m\times n}, \Sigma,V\in \Re^{n \times n}[/tex]. See en.wikipedia.org/wiki/Singular_value_decomposition for details. Every good linear algebra software should have an algorithm. Let [tex]\hat{U}\in \Re^{m\times k},\ \hat{\Sigma} \in \Re^{k \times k},\ \hat{V}\in \Re^{n \times k}[/tex] where k is the numerical rank of A (ignore smallest singular information).
Your least squares solution is [tex]x=A^+b=\hat{V}\hat{\Sigma}^{-1}\hat{U}^Tb[/tex].
This should work if your matrix is decently sized (around 1000 unknowns).
Another plus is that of all the residual minimizers, this x has a minimal 2-norm.
Matthew
