Linear momentum- moving blocks and attatched spring
The discussion centers on a physics problem involving two blocks and a spring, where block 1 (mass 1.6 kg) moves at 12 m/s and block 2 (mass 4.8 kg) at 2.8 m/s on a frictionless surface. The maximum compression of the spring with a spring constant of 1100 N/m occurs when both blocks have the same velocity. The conservation of momentum and energy principles are applied to derive the maximum compression, which is calculated to be approximately 0.4143 m. The key equations used include momentum conservation and kinetic energy relationships.
  • Understanding of linear momentum and its conservation
  • Familiarity with kinetic energy and potential energy in spring systems
  • Knowledge of the equations of motion in physics
  • Ability to solve quadratic equations
  • Study the principles of conservation of momentum in elastic and inelastic collisions
  • Learn about energy conservation in mechanical systems, particularly involving springs
  • Explore the relationship between kinetic energy and potential energy in oscillatory systems
  • Practice solving problems involving multiple bodies and spring interactions
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of momentum and energy conservation in collision scenarios.
rmunoz
In the figure below, block 1 (mass 1.6 kg) is moving rightward at 12 m/s and block 2 (mass 4.8 kg) is moving rightward at 2.8 m/s. The surface is frictionless, and a spring with spring constant of 1100 N/m is fixed to block 2. When the blocks collide, the compression of the spring is maximum at the instant the blocks have the same velocity. Find the maximum compression.
http://www.webassign.net/halliday8e/pc/halliday8019c09/halliday8019c09-fig-0065.htm
m1(i)v1(i) + m2(i)v2(i) = m1(f)v1(f) + m2(f)v2(f)
p=mv
KE=1/2mv^{2}
Work-spring=1/2kx^{2}
Momentum before collision:
P1+P2= Psys
m1v1 + m2v2 = Psys
1.6kg*12m/s +4.8kg*2.8m/s= 19.2 kg*m/s + 13.44 kg*m/s = 32.64 kg*m/s
work done by spring on object 1 = change in object 1's kinetic energy ?
Momentum after collision of object 1 will be negative, and momentum of object 2 will have increased in the positive direction.
Questions:
1) how do i relate the compression of the spring to the linear momentum of the system?
2) how do i tell weather or not linear momentum is conserved (in general, not just in the scope of this problem)
3) how can i relate the change in kinetic energy due to the spring to the change in the momentum of object 1 and 2? (or is that at all how i am supposed to approach this problem)
Hi rumonz
can't see the picture but i assume block 1 impacts the spring on block 2?
As for your questions
1) energy of a whole system is always conserved (by a whole system I mean everything that is interacting) - look at the energy in your system
2) linear momentum of a whole system is always conserved
3) You're on the right track... Kinetic energy and momentum are both functions of velocity. And the question asks you the compression of the spring when both masess are moving at the same velocity. Can you solve for this velocity?
So i solved for the velocity by the following:
Psys=32.64kg*ms
V1=V2
m1v1(comp) + m2v2(comp) = 32.64kg*m/s
v1comp(m1 + m2)= 32.64kg*m/s
v1comp=[32.64kg*m/s]/[6.4kg]
v1comp= 5.1 m/s
Now I am stuck again. I understand that \DeltaKE= work and I think that has some relation to the change in kinetic energy of mass 1 by the spring system aka 1/2Kx^2. I want to say that the kinetic energy of mass 1 can be described by adding -1/2Kx^2 (which should be a negative value since its pushing away from object one) to the initial kinetic energy of mass 1. This is what i did to solve for the compression:
1/2m1vo^2 - 1/2kx^2 = KE m1 at fullcompression= Pcompm1(vcomp)(1/2)
yielding:
x^2 (compression distance) = [(m1vo^2)-Pcomp_m1*(vcomp)]/(K)
x= \sqrt{[230.4kg*m^2/s^2 - 41.616kg* m^2/s^2]/1100}
x= .4143 m
What did i do wrong? I suspect I missed something quite large, because the numbers are really not coming out too friendly.
help?
I'm not too sure what you did in the 2nd part
the total energy of the system will be conserved at all time in this case, that amounts to:
E = KE + PE = (\frac{1}{2} m_1 v_1^2+ \frac{1}{2} m_2 v_2^2) + \frac{1}{2}k x^2
  • · Replies 33 ·
  • · Replies 31 ·
  • · Replies 16 ·
