- 42,954
- 10,553
Yes.Thermofox said:Now can I say that ##W_{\text{friction}}= \Delta l \mu_d g m_b##?
Depending on the frame of reference you choose, you could consider that the block moves ##x## one way and the slab moves ##\Delta l-x## the other way. So the block does work ##\mu_kxm_bg## against friction while the slab does work ##\mu_k(\Delta l-x)m_bg## against friction. The total work done against friction is always ##\mu_k\Delta lm_bg##.Thermofox said:I'm not sure because the work is done on 2 surfaces that are moving.
You understand that you do not need to consider that, right?Thermofox said:But what would happen when the block falls from the slab.
A system is whatever you define it to be.Thermofox said:Is our system still valid or as soon as they detach, they can no longer be considered as a system?
Certainly it will behave differently after detachment.
