Linear Operator T on Vector Space V: Unique Matrix A in Ordered Bases B
  • Level: Graduate
  • Thread starter Thread starter Abuattallah
    Linear
Abuattallah
Hello,
I am a grad student preparing for a quals. I am using H. and Kunze book.
the problem is:
let V be a n-dim vector space over F. and let [itex]B[/itex]={[itex]a_1,a_2,..., a_n[/itex]} be an ordered bases for V.
a- According to them 1, there is a unique Linear operator T on V such that
[itex]Ta_i=a_{(i+1)}[/itex] , i=1,...,n. and [itex]Ta_n=0[/itex].
what is the matrix [itex]A[/itex] of [itex]T[/itex] in the ordered bases B.
b- prove that [itex]T^n=0, and\ \ \ T^{n-1}≠ 0[/itex].
c- Let S be any linear operator on V such that [itex]S^n=0\ \ \ but\ \ \ S^{n-1}≠0[/itex]. Prove that there is an ordered bases [itex]B'[/itex] such that the matrix of [itex]S[/itex] in the bases [itex]B'[/itex] is the matrix [itex]A[/itex] of part (a).
Solution Attempt.
Obviously we have for (a)[itex]A= \begin{bmatrix}<br /> 0 & 0&... & 0 &0\\<br /> 1 & 0 & 0&...&0 \\<br /> 0&1&0&...&0\\<br /> .\\<br /> .\\<br /> 0&0&...&1&0<br /> \end{bmatrix}[/itex]
for (b) its obvious.
my problem is with the last question. I tried to justfy it by two ways, the first one is to find an ivertible linear transformation [itex]U:V→V[/itex] such that [itex]S=UTU^{-1}[/itex], then we will be done and such a bases exists. The second way is that I am trying to show the follwing:
there exist at least on vector in the bases [itex]B[/itex] such that [itex]S^ia_i≠0[/itex] for [itex]i=1,..,n-1.[/itex] and I am considering the set [itex]B'=[/itex]{[itex]a_i, Sa_i,S^2a_i,...,S^{n-1}a_i[/itex]}. Note if we proved [itex]B'[/itex] is a bases, then [itex]<s>_{B'}=A</s>[/itex].i.e. the matrix of [itex]S[/itex] relative to the bases [itex]B'[/itex] is A.
Unfotunatly, I could not get to an end with both ways.
Am I doing the right thing? Any suggestions?.
Thank you in Advance.
Welcome to PF!
Hello Abuattallah! Welcome to PF! :smile:
Hint: use the fact that Sn-1 ≠ 0 :wink:​
Thank you tiny-tim.
This is my try:
consider the base [itex]B'=[/itex]{[itex]a,Sa,...,S^{n-1}a[/itex]}, for some [itex]a[/itex] where [itex]S^ia≠0, \forall i≤n-1[/itex], now for the sake of simplicity let's call them as follow [itex]a=a_1, Sa=a_2,...,S^ia=a_{i+1},...,S^{n-1}=a_n[/itex],Consider the follwing
[itex]c_1a_1+...+c_na_n=0[/itex] ... (1)
Aplly [itex]S^{n-1}[/itex] to both sides of (1), we get
[itex]c_1a_n=0→c_1=0[/itex],
now apply [itex]S^{n-2}[/itex] to (1), we get
[itex]c_2a_n=0→c_2=0[/itex], Continueing this way, we will get all [itex]c_i=0\ \ , \ \forall i=1,...,n[/itex], Hence the set [itex]B'[/itex] is linearly independent.
Any comments on my method?
Thanks in Advance.
Hi Abuattallah! :wink:
Yes, that's right. :smile:
Just a few "tweaks" needed …
Start with "Since Sn-1 ≠ 0, there exists an a such that …"
Then "So define the ordered set B' = {…}" (you can't call it a basis yet :wink:)
And end "So B' is an independent ordered subset whose cardinality is the same as the dimension of V, and is therefore a basis for V"
By the way, "bases" is the plural of "basis". We speak of a basis for a vector space.
Thank you so much Tiny-Tim.
and thanks for word correction, English is my second language ; ).
You have all a wonderful day,
Abuattallah
Your English is far better than my (put just about any language here!).
