Linear regression and bivariate normal, is there a relationship?
3 replies · 4K views · last reply
CantorSet
Hi everyone,
This is not a homework question. I just want to understand an aspect of linear regression better. The book "Applied Linear Models" by Kutchner et al, states that a linear regression model is of the form
[tex]Y_i = B_0 + B_1 X_i + \epsilon_i[/tex]
where
[itex]Y_i[/itex] is the value of the response variable in the ith trial
[itex]B_0, B_1[/itex] are parameters
[itex]X_i[/itex] is a known constant
[itex]\epsilon_i[/itex] is a random variable, normally distributed.
Therefore, [itex]Y_i[/itex] is also a random variable, normally distributed but [itex]X_i[/itex] is a constant.
This confused me a bit because I always associated linear regression with the bivariate normal distribution. That is, the underlying assumption of linear regression is the data [itex]\{(x_1,y_1), (x_2,y_2),...,(x_n,y_x) \}[/itex] is sampled from a bivariate normal distribution. In which case, both X and Y are random variables. But in the formulation above, X is a known constant, while [itex]\epsilon[/itex] and therefore [itex]Y[/itex] are the random variables.
So in summary, what is the connection (if any) is between linear regression as formulated by Kutner and the bivariate normal.
I've never seen a treatment of regression that made that assumption. Are you confusing linear regession with some sort of "total least squares" regression?
http://en.wikipedia.org/wiki/Total_least_squares
Thanks for responding, Stephen.
Yea, that was my own confusion for making that assumption. Thanks for clearing that up.
By the way, total least squares is just a generalization of linear regression in that the curve you're fitting the data points to can be polynomials with degrees higher than 1, right? Or is there more to total least squares?
Total least squares treats both X and Y as random variables.
